13-10-2007, 09:56 PM
Slow,slow
Internet speed became very very slow. I tired AVG-Anti virus free,Adware,spybot,defragment,etc. but no use. How to make it speed again?
13-10-2007, 11:29 PM
TechTin.com
Re: Slow,slow
Speed depend on many things.
1) Package and plan of your ISP
2) programs running on your system
3) Backbone bandwidth
So, tell me...who is your ISP, what plan you have??
14-10-2007, 12:55 PM
Re: Slow,slow
The internet speed was good before. But after uninstalling some softwares and installing Internet cleanup Software,it becomes slow. When I attempt to uninstall Internet CleanUp,it leads to a lot of problems.I have given passward to Personal Info protector on this software and how to remove the passward and unistall them successfully.
I tried to clean up the Registry using RegCleaner, but it also leads to a lot of problem. How to clean up them without any problem?
14-10-2007, 01:03 PM
I<3C0FF$£
Re: Slow,slow
http://www.download.com/
Search the above URL for Wise Registry Cleaner and Wise Disk Cleaner under Utilities or through the search bar.
Ring up your ISP and ask if there is any problems in your region or reasons why your internet could be slow. Go download and install Mozilla Firefox and set that to your primary web surfing program. Firefox uses alot less memory than Internet Explorer.
Delete all the other anti-virus/anti-spyware programs and leave AVG and Spybot. If you run two anti-virus programs at the same time they de-stablise each other.
These arn't mandatory but can help.
I dare say these are my horrible specs
OS: WinXP Pro SP2 CPU: AMD Athlon XP 2500 (Barton) , 2.16 GHz Graphics: Radeon 9250 Sound: NVIDIA nForce HD: 189.91GB Total Physical Memory: 768 MB
15-10-2007, 07:41 PM
Re: Slow,slow
i have the same prblm but i can install the AVG antispywrae after that the speed is good
click to download
http://free.grisoft.com/doc/download...yware/us/frt/0
and also this is problem of browser that u use try Mozilla Firefox for fast browsing
15-10-2007, 07:50 PM
TechTin.com
Re: Slow,slow
please explain your problem.I am not getting everything
15-10-2007, 08:02 PM
Re: Slow,slow
After unistalling some softwares,the internet speed became very very slow. I cannot uninstall a software completely. Refer to my first question in the Forum carefully.
15-10-2007, 08:04 PM
Fast 'N' Furious
Re: Slow,slow
@ kumarn_2004 - clarify these questions
1. who is your service provider ?
2. How much speed you usually got before ?
3. How much speed you're getting now ?
one tip : If everything fails try to reinstall windows & only install software that you really need from trusted source. Don't overburden your OS by installing beta & other softwares.
15-10-2007, 08:25 PM
Cool and Calm
Re: Slow,slow
have heard tat bcoz of some local area ISP's, such problems come....which is your isp?
When Roger's at play, opponents pray..!!!!! :twisted:
15-10-2007, 09:06 PM
TechTin.com
Re: Slow,slow
there is no issue of internet speed with any software installed.I dont know why you are facing such problem.Can you name the software because of which you are facing this problem.
15-10-2007, 10:07 PM
Re: Slow,slow
Originally Posted by gauravjaryal
I used Mozilla Firefox before. But Oper is more faster than Mozilla Firefox.
Internet Cleanup
Reason: Automerged Doublepost
15-10-2007, 11:15 PM
TechTin.com
Re: Slow,slow
Internet Cleanup
I don't think Internet cleanup boost internet speed.It only does to clean ofline files, cookies, cache and others.
16-10-2007, 03:35 PM
Re: Slow,slow
Yes, you are right. Using AVGAnti-spyware solved my problem.
