Old 12-10-2007, 07:48 PM   #1 (permalink)
Default USB Problem
I have a problem with my pen drive. I sure it's kind of virus but my AV is not able to detct it. I have 2Gb i-ball open drive. Few days back i had copied a movie from my PC to pen drive. My PC is not inffected that i know because i scan every week. Now whenever i see properties of my drive it shows 1.23 GB space as used all though my drive is empty!!! Whenever i try to refresh in the drive that movie file comes back in the drive. I have even deleted that movie from my PC. So i'm sure it's virus. I've used my AV NOD32 as well as Spybot: S & D . Problem still persists. Can nebody help me out of this.
The Nilay is offline
Old 12-10-2007, 08:00 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: USB Problem
did u format ur usb? If ys and u r getting this problem then ,
Try Kaspersky 30 day trial....
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 12-10-2007, 08:42 PM   #3 (permalink)
i'm not able to format my pen drive. But i can safely remove it. Do i still need to use kaspersky. or something else can be done?
Old 12-10-2007, 08:54 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
download unlocker from here:
http://www.softpedia.com/get/System/...Unlocker.shtml
Find what is blocking ..and than unlock it, than format your USB drive.
ravi_9793 is offline
Old 13-10-2007, 04:17 PM   #5 (permalink)
I tried to unlock it, but it shows nothing is unlocking it. Still i'm not able to format it.
Old 13-10-2007, 05:27 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
format ur USB drive on other computer.There is some problem in ur system.
Old 13-10-2007, 07:45 PM   #7 (permalink)
Back in Power
almighty's Avatar
just format ur usb......................
and try to scan with kaspersky.........
almighty is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by Niilesh
