LinkBack (5) Thread Tools Display Modes
Old 08-10-2007, 07:18 PM   5 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Help:: need drivers for VISTA HUAWEI smart AX MT841 drivers
Help::
I got a new Laptop with VIsta Home Basic Preloaded..
I need the drivers for the HUAWEI Smart Ax MT841 for the DATAONE BROADBAND connection....
Please help.....
sudheer17682 is offline
Old 09-10-2007, 12:26 AM   #2 (permalink)
hmmmmmmmmmmmmm's Avatar
Default Re: Help:: need drivers for VISTA HUAWEI smart AX MT841 drivers
driver is for usb
u can connect via rj45 socket na huh
Sellin Rapidshare Account 30 Days Validity for 6 $ PM ME
hmmmmmmmmmmmmm is offline
Old 09-10-2007, 11:29 AM   #3 (permalink)
gowtham's Avatar
jus connect the modem through ethernet, then u wont need ANY drivers for the modem! njoy!
There is always a better way to do it. Go find it!
Thomas Alava Edison
gowtham is offline
Old 09-10-2007, 06:38 PM   #4 (permalink)
HUAWEI Smart AX MT 841 Driver
You do not require any driver if you connect modem thru Ethernet (as suggested by Gowtham.)
However, if you need to connect thru USB, then the following file may be of helpful to you. It is working for XP but I don't know about Vista.
http://rapidshare.com/files/61340319...USB_driver.zip
Inform whether it could solve your problem.
senthilvels is offline
Old 10-10-2007, 10:47 AM   #5 (permalink)
Thnks BHai loggg......
Now working on VISTA too
Old 02-08-2008, 12:56 PM   #6 (permalink)
Unhappy Re: Help:: need drivers for VISTA HUAWEI smart AX MT841 drivers
Its the same driver supplied with modem and I downloaded the driver from the link but not able to install as its not supporting Vista
oshin is offline
Old 30-08-2008, 07:19 AM   #7 (permalink)
Start setup of the modem driver.when requested connect the modem. and u can see installation status on the system tray(where windows time is shown). when its shows the message driver installed and ur hardware is ready to use . dnt wait for setup application to finish.. jst go to start menu and click restart. i hope this work with u. in ma case it worked wll in vista
clintiii is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/70161-help-need-drivers-vista-huawei-smart-ax-mt841-drivers.html
Mt 6235 Driver - Download This thread Refback 23-02-2012 10:04 AM
Drivers Huawei Smartax Mt882 - Download This thread Refback 02-02-2012 04:01 PM
Mt.6225.driver - Download This thread Refback 12-01-2011 05:23 AM
Smartax MT 882 Driver - Download This thread Refback 31-08-2010 11:19 AM
Driver Help - Download This thread Refback 22-07-2010 10:42 AM
DSL Drivers for Vista LegendKiller Software Q&A 5 02-08-2008 01:07 PM
Vista Drivers. slash_89 Software Q&A 8 01-05-2007 02:18 PM
Need Drivers for VISTA Help PLZ pra_2006 Software Q&A 12 12-03-2007 09:36 PM
Need Help bout Huawei MT841 modem. prateek_san Hardware Q&A 5 24-02-2007 09:25 AM
- by Niilesh
