Old 07-10-2007, 03:28 PM   #1 (permalink)
Default Setting the default priority level for an application
Hi all
i need to know whether theres a way to change the default priority level of an executable. like an application for eg: utorrent, googletalk, etc...
i want these application to run with a predetermined priority level.
TIA
Manmay
manmay is offline
Old 07-10-2007, 11:28 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Setting the default priority level for an application
Open Taskmanager, switch to Processes Tab and right click on application name and choose set priority. You can set priority upto 6 levels.
navjotjsingh is offline
Old 07-10-2007, 11:43 PM   #3 (permalink)
anand1's Avatar
Ya it might work i think so....
Technology On The Fly
anand1 is offline
Old 08-10-2007, 12:03 AM   #4 (permalink)
But be sure....some times it damages ur system
Lakshmi kanth is offline
Old 08-10-2007, 12:10 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
I'm sure he wouldn't have asked that cause he KNOWS there exists priorities. He's asking how to set them to start with a default priority.
For starting via CMD (Making BAT files in process), see:
http://www.windowsitpro.com/Article/...500/14500.html
For using a tool instead, try:
http://www.softpedia.com/get/Desktop...y-Master.shtml
QwertyManiac is offline
Old 08-10-2007, 12:53 AM   #6 (permalink)
thanx qwerty....
so any ideas....?
manmay is offline
Setting Default CD ROM Drive rakesh_1024 Software Q&A 8 19-02-2007 05:13 AM
How to change default application for VCDs in Ubuntu? vinayasurya Open Source 7 12-07-2006 08:14 PM
Internet Explorer Gets Top Priority Kannan Internet & WWW 14 05-08-2005 12:55 PM
Software priority ! ! ! ax3 Software Q&A 2 01-07-2005 11:45 AM
setting priority of a task in task manager zoom QnA (read only) 4 23-02-2005 12:11 AM
- by Niilesh
