Old 06-10-2007, 09:45 PM   #1 (permalink)
Unhappy restart problem
when i am restarting my computer it hangs after the screen displays "windows is shutting down".
i have formatted my system twice thinking it to be a problem of windows installation but the problem is still not solved
slyfox is offline
Old 06-10-2007, 11:19 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: restart problem
Does this happen during normal shutdown??
Life is as complicated as you say it is.
shady_inc is offline
Old 07-10-2007, 08:53 AM   #3 (permalink)
no this doesn't happen during normal shutdown.
slyfox is offline
Old 07-10-2007, 05:34 PM   #4 (permalink)
shady_inc's Avatar
Have a look in event viewer [control panel>administrative tools>event viewer] and look for any red icons there.
You can also have a look here:
http://www.aumha.org/win5/a/shtdwnxp.php
Problem regarding restart Ankit Agrawal Hardware Q&A 2 20-07-2008 02:11 PM
Restart problem... prasad_den Hardware Q&A 4 20-07-2008 01:58 PM
Help : Pc Restart problem kg_87 Software Q&A 13 25-06-2007 10:21 AM
Restart Problem ashu_dps Software Q&A 4 25-10-2006 04:10 PM
~~~~~~Restart Problem~~~~~~ freezer QnA (read only) 2 26-10-2005 02:43 PM
- by Niilesh
