Old 05-10-2007, 08:09 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Unhappy Urgent help:Unmountable boot volume
Hi all,
I got this BSOD message 'Unmountable boot volume' after I installed XP pro over my Vista partition.
I initially had Vista OS. But then I had installed XP Pro on a separate partition. The Vista Boot Manager was gone. Due to some problems, I decided to install fresh new XP Pro on my Vista partition. So I manually deleted the folders and files(hidden too) of Vista partition.
During the installation process it asked where I wanted to install OS.. I selected the Vista partition and in the next window I selected 'Leave the file system intact' instead of formatting. The installation was successful.
In the next boot, after the boot screen it gives me message that that my OS partition(one on which Vista was installed) needs to be checked for consistency. I allowed the CHKDSK process to continue.
All 3 stages of CHKDSK were completed. Then before I could see the login screen I got the BSOD message.
I googled this error and what it suggested that 'boot.ini' might be missing and I need to goto Recovery Console to fix this boot error.
But what I know is that after we install XP, it overwrites any previous boot record and updates with its own. So how come my boot.ini file is missing?
Is this because I deleted Vista files?
Now I don't have my CDROM working so the XP boot disc option will not work. Is their any other option?
Please help seriously.
http://twitter.com/blueshift155
blueshift is offline
Old 05-10-2007, 08:26 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: Urgent help:Unmountable boot volume
hmmm. CD Drive should still work. Try going through the bios once again. Completely format the Vista partition and reinstall xp if necessary.
Again, to repeat, xp or any other problem on your hard drive should not affect booting from your cd drive.
Life is too short. Have fun.
ilugd is offline
Win XP Issue - ACPI.sys/Unmountable Boot Device arijitraja Software Q&A 2 24-06-2007 08:07 PM
Don't Manipulate a Single Volume Block during Windows Vista Boot! Third Eye Technology News 1 05-05-2007 09:39 PM
Unmountable Boot Volume mbc_1824 Software Q&A 8 11-04-2006 12:07 AM
UNMOUNTABLE BOOT VOLUMEerror , IS the HDD finished ? Huzefa Software Q&A 6 23-01-2006 11:33 AM
Unmountable boot volume mohit Software Q&A 3 01-04-2005 11:49 PM
- by Niilesh
