Old 05-10-2007, 02:43 PM   #1 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Limewire problem
guys im using limewire but whenever i open it it just closes in 1 second, i did restarting virus scanning all the stuff but still this happens any help?
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 05-10-2007, 02:57 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Limewire problem
Did you reinstall it?
Third Eye is online now
Old 05-10-2007, 04:39 PM   #3 (permalink)
entrana's Avatar
yes yes i just said i did all thsoe normal stuff
entrana is offline
Old 05-10-2007, 05:05 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Reinstall java VM. Most of the times, that the culprit. Can you run any other Java based apps? (like azureus etc.?)
infra_red_dude is offline
Old 05-10-2007, 06:14 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
@infra_red_dude-YES, reinstall JRE from the sun java website. When you download with a download manager try to download without splitting the file, it sometimes corrupts. Use wget or WinWget for Windows if you know how
NucleusKore is offline
Old 05-10-2007, 08:05 PM   #6 (permalink)
entrana's Avatar
i can run azureus nicely
entrana is offline
Old 06-10-2007, 10:11 PM   #7 (permalink)
entrana's Avatar
help?
entrana is offline
Old 06-10-2007, 10:17 PM   #8 (permalink)
TheSaint
Option 1. do you have BearShare or any other p2p? Just read the last post in this thread
http://www.gnutellaforums.com/genera...isappears.html
Option 2. Uninstall JRE. Install Limewire WITH the bundled JRE
Old 06-10-2007, 11:00 PM   #9 (permalink)
entrana's Avatar
tried dude
entrana is offline
Old 07-10-2007, 12:48 AM   #10 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
^^ If all fails do a windows reinstall.
Well most likely the problem with a system file since u said u reinstalled the java and limewire.
Quiz_Master is offline
Old 07-10-2007, 07:23 AM   #11 (permalink)
TheSaint
Am stumped, sorry
Old 07-10-2007, 08:26 AM   #12 (permalink)
outlook is not working
ramanradha is offline
Old 07-10-2007, 04:56 PM   #13 (permalink)
Pee into the Wind...
shady_inc's Avatar
Try deleting the limewire preferences folder.Assuming you are using XP and installed it in C:\ drive,it can be found in
C:\Documents and Settings\yourusername\Application Data\LimeWire.Do this while limewire is closed!!
Life is as complicated as you say it is.
shady_inc is offline
Old 08-10-2007, 08:30 AM   #14 (permalink)
entrana's Avatar
aint working
entrana is offline
Old 08-10-2007, 04:18 PM   #15 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
do a clean uninstallation = remove all files related 2 limewire ..... then restart ... & install again .......
... W H O T ...
ax3 is offline
Old 08-10-2007, 05:35 PM   #16 (permalink)
entrana's Avatar
i did that
entrana is offline
Limewire pro Problem Third Eye Software Q&A 9 22-07-2006 08:30 PM
Limewire naru QnA (read only) 18 25-06-2006 09:39 PM
Limewire Problem??? go4saket QnA (read only) 3 14-01-2006 04:44 PM
limewire BLITZ~KRIEG! QnA (read only) 16 15-09-2005 10:05 PM
- by Niilesh
