Old 03-10-2007, 01:24 PM   #1 (permalink)
Web Design Hobbyist
Question WinXp Pro trouble
Hi, I am facing a strange problem with my winXp pro installation. for some time now, whenever i try to show the hidden folders and/or system files by tools--->folder options----> view and setting to show the hidden folders and system files .....the system turns to the default settings automatically and my preference does not get saved. I ran full scan with Avast home and spybot s&d but no threat detected even with the latest definitions.Please help me overcome the problem.do i need to reinstall windows?
Neel Kamal Kalita
Web: http://neelsworld.in
dreamzchm is offline
Old 03-10-2007, 01:45 PM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: WinXp Pro trouble
Buddy you dont have any virus in your system, but probably you had that popular USB device virus previously, and one of the many things it does is disabling this hidden file option. I dont know the solution for it, so i guess you ask users like anand who are MVPs. they must have some info on registry setting that need to be cured. Sorry! And dont reinstall in a hurry! First try if you get some answers.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 04-10-2007, 03:07 PM   #3 (permalink)
Web Design Hobbyist
Thanks buddy, i will try to find out if there's any solution out there by visiting spacialized forums.....
Neel Kamal Kalita
Old 04-10-2007, 04:11 PM   #4 (permalink)
Web developer
narangz's Avatar
Go to registry editor by typing regedit in the run box.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
narangz is offline
Old 09-10-2007, 05:27 PM   #5 (permalink)
Web Design Hobbyist
Hey buddy, i tried ur trick but it did not help... i m still having the same problem....!!!
Neel Kamal Kalita
Old 09-10-2007, 06:33 PM   #6 (permalink)
See, thats what i said. The setting that narangz is telling about is same, what is changed by the Folder Options dialog. Doing it by hand will have no effect.
Help Need Urgently (WinXP user Problem) i am in a big trouble............... satyamy Software Q&A 6 18-03-2007 05:20 PM
WinXP Home(German) to WinXP Home(English) PrinceHeart Software Q&A 3 17-09-2006 01:50 AM
Installing WinXP Pro over WinXP Home rushab143 Software Q&A 9 12-02-2006 05:04 PM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
One WinXP Inside another WinXP (No Multiboot). How ? Kannan Software Q&A 5 16-06-2005 10:33 PM
- by Niilesh
