Old 02-10-2007, 03:44 AM   #1 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Red face XP freezing
i have two OS in my pc one creating problem after finishing boot up system gonna freeze means no movement mouse and keyboard then i started repair XP from CD the after few minutes the CD key window comes for inter XP CD key but again Xp freeze then i restart the system again and the problem still plz guys help me out first time i faced this type of problem
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 02-10-2007, 07:43 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: XP freezing
Remove all other external device(printer, pendrive n others) connected to your PC.Than try to repair your XP.If it again hangs between repair process,than remove your graphics card. Than try to repair your XP.
I think this must solve your problem.
If after all these you can't repair your XP..than I am scared you have to do a fresh installation of windows XP.
AS, you said, your system works fine on other OS.This means, this is not a hardware compatibility issue. So, any software installed (i.e. antivirus, firewall, system utilities, etc) is making trouble.
ravi_9793 is offline
Old 02-10-2007, 04:25 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
looking @ ur config .... WOW ......
try switching ur RAM ...... & recall which software u INSTALLED recently ....... & try renaming that .exe 2 .aexe ........ try it out .......
... W H O T ...
ax3 is offline
Old 03-10-2007, 12:35 AM   #4 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: XP freezing
formated hmm
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 03-10-2007, 12:44 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by NIGHTMARE
formated hmm
is it working fine now???
pc freezing with a cracking sound r_raman Hardware Q&A 11 29-01-2007 03:27 AM
PC Freezing , and not becasue of the winter ! Maverick340 Hardware Q&A 4 30-11-2006 09:00 PM
Freezing Opera...... vrnoormd Software Q&A 10 03-01-2006 05:09 PM
HELP ME!!! MY PC IS FREEZING sreevirus Software Q&A 5 10-10-2004 12:47 AM
Why only games are freezing? bhalchandra Software Q&A 8 06-09-2004 07:11 PM
- by Niilesh
