Old 02-10-2007, 12:55 AM   #1 (permalink)
Exclamation An irking problem with dvd drive
Hi everyone,
I av a dual os with Win Xp in D drive and Win 98 in C drive. I recently got a weird and an irking problem - my dvd drive ejects the tray periodically for every 30 secs or so whenever I boot into win 98(No prob with XP). I realize I've been infected by some sort of spyware. I googled and found few solutions of deleting registry keys in HKEY_LOCAL MACHINE but that didnt work. Its a RundlI32/rundli sort of damn thin runnin in the computer memory. Earlier I had the same prob with XP, But on deleting the registry keys the problem was solved in XP.But I cudnt solve it in 98. PLZ HELP ME A WAY OUT!!!!!!!!!!
D_Sathish is offline
Old 02-10-2007, 11:48 AM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: An irking problem with dvd drive
YOU MAY BE RIGHT THAT MAY BE A VIRUS OR SPYWARE BUT ANY HOW TRY THIS AFTER PERFORMING SYSTEM RESTORE,
Disable your cd device in device manager when cd tray is open,then you restart the system
secondly verify if any of your bus or power cables are bad
the most systems facing this type of error is due to the software naming DIRECTCD did you installe dthat software if so disable that service
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 02-10-2007, 12:01 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Ahem .. Is it a Samsung drive ..??
If not .. Then try downloading Malicious Software Removal Tool and scanning your system with it .. It takes care of most common viruses around ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 02-10-2007, 10:48 PM   #4 (permalink)
a_tif's Avatar
Originally Posted by D_Sathish
Hi everyone,
if u cant remove the virus format ur win 98 drive
a_tif is offline
Dvd Drive Problem 56561 Hardware Q&A 3 27-07-2007 12:09 AM
my cd drive has a problem yogi23 Hardware Q&A 4 29-11-2006 08:51 AM
DVD and Cd Drive problem!!!!!!! pranavrahul Hardware Q&A 7 06-01-2006 09:56 PM
pen drive problem ! esumitkumar QnA (read only) 5 15-08-2005 02:26 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by Niilesh
