Old 30-09-2007, 11:29 AM   #1 (permalink)
Angry audio problems wit uTorrent
i can download the videos and start watching them on windows media player but i dont have sound sumthing about missing adio codec can sum 1 please helpme.
chico is offline
Old 30-09-2007, 11:36 AM   #2 (permalink)
Default Re: audio problems wit uTorrent
maybe some codec probs.
try DLing k-lite codec pack.
it works.
SunnyChahal is offline
Old 30-09-2007, 05:00 PM   #3 (permalink)
where can i get the dling k-lite cocdec pack
chico is offline
Old 30-09-2007, 05:08 PM   #4 (permalink)
Married!
Rahim's Avatar
Hey chico here you go K-Lite Codec Pack
BTW change your title, its misleading.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 01-10-2007, 01:02 AM   #5 (permalink)
Smile Re: audio problems wit uTorrent
thanks u guys ill let you know if it helps
chico is offline
Old 01-10-2007, 01:16 AM   #6 (permalink)
ayush_chh's Avatar
or u can play the files using VLC player, it plays nearly all the media files..
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 01-10-2007, 02:43 AM   #7 (permalink)
Talking Re: it all working
thank you guys so much yo, i got every thing working got sound on my videos once again thanks so much you guy are the pimpness
chico is offline
Old 01-10-2007, 02:36 PM   #8 (permalink)
Married!
Rahim's Avatar
Default Re: it all working
Anytime to pimp your ride....
Rahim is offline
Old 01-10-2007, 02:58 PM   #9 (permalink)
did klite work orVLc?
Old 03-10-2007, 03:06 AM   #10 (permalink)
yeah it worked. but can you guys help with another prob i cant burn the movies i downloaded im using media palyer to burn them but not burning sothing about it being anable to burn form the source. got any info
chico is offline
High Defination Audio Problems in Intel 946 GZIS Mobo In Vista dr_jimit Software Q&A 1 13-08-2007 12:51 AM
Partion and Audio problems in Mandriva linux :? baccilus Open Source 78 09-04-2006 09:13 PM
[color=red][size=18]PROBLEMS WITH MAKING AUDIO CD[/s[/color] kguragain Hardware Q&A 4 29-12-2005 07:14 AM
need an audio converter for converting real audio to mp3 asdf1223 QnA (read only) 3 18-09-2005 08:32 PM
- by Niilesh
