29-09-2007, 10:51 PM
speed up pc performance ?
is there any software that really speed up windows performance ??
29-09-2007, 11:01 PM
dig_boy_dig,dig !
Re: speed up pc performance ?
I dont know if there is such software available or not. But u can do something like removing unnecessary registry entries through CCleaner.
Disk defrag atleast once in a month. unnecessary programme which are running in background. If u are able to find out that file.
Lets see what other say,
________________________________________________
I like signature after 10 P.M.
29-09-2007, 11:35 PM
METHOD 1
1. go to start
2. click "RUN"
3. type "MSCONFIG"
4. goto startup tab
5. deselect all
6. goto services tab
7. click hide all microsoft services
8. click deselect all
9. click OK 7 RESTART
METHOD 2
1. key press "WINDOWS+PAUSEBREAK"
2. goto advanced tab
3. click setting under performance
4. tick - setting for best performance and then make sure only 7th, 8th and last 2 options are ticked
5. OK
and there u go with doubly speeded BRAND NEW WINDOWS
cheers
30-09-2007, 06:10 AM
when i deselect all the start up items, many programs do not run properly
30-09-2007, 08:04 AM
tuneup utilities 2007
system mechanic 7
| Athlon II X4 635 @ 2.9Ghz | | Gigabyte GA-MA785GMT-US2H | | Kingston 2x2 Gb 1333Mhz DDR3 | | WDC 500Gb Green | | Palit GTS 250 512mb | | Tagan 500W | | Samsung B2030 | | Lg DVD Writer |
30-09-2007, 09:03 AM
TechTin.com
some common tips:
1) Avoid big theme..infact prefer windows default theme.
2) Do regular disk cleanup....disk defragment.....registry cleanup, registry degragment.
for this, there are many softwares like...tuneUp, ccleaner.
3) Remone unwanted program at startup...using msconfig command in run.
there are lots more tips here
MASTER TUTORIAL: Make Your Windows XP Super Fast !!!
30-09-2007, 11:48 AM
Distinguished Member
use tune up utilities
else see this
MAKE WINXP STARTUP/SHUTDOWN FASTER !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
30-09-2007, 11:54 AM
here r some tips:
1.dont install faltu apps.
2.use a decent antivirus.
3.dont use more than 2 OSs.
4.use ccleaner to clean temp files and al other crap files.- ccleaner.com
5.use System mechanic 7 Pro.(u wil have to buy it)(or some other ways)
no need for any other tune ups.
use a comp like a comp and dont mess up with it.
like this ur comp will work perfect.
Enjoy computing.
30-09-2007, 12:06 PM
Disable unwanted services,don't install vista transformation & other such packs,defragment,remove umwanted startup entries,search google for reg tweaks & apply them,install & use tweak ui & tony art easycleaner,install avast & spybot & scan regularly.
30-09-2007, 12:20 PM
Pee into the Wind...
Originally Posted by crazyforever
METHOD 1
1. go to start
2. click "RUN"
3. type "MSCONFIG"
4. goto startup tab
5. deselect all
8. click hide all
METHOD 2
5. OK
cheers
I would disagree with the first method.msconfig is meant for troubleshooting.Disable startup apps from within the program itself.
Life is as complicated as you say it is.
01-10-2007, 06:43 PM
troubleshooting ?
wud u plz elaborate wat do u mean by troubleshootin in dis context only
nd by d way hav u even tried method 1
am sure it wud result in stoppin all the automatically running softwares including antiviruses but that for that u hav an option too
simply select the programs that u want to run on startup
now do i have to xplain that 1 too !!!!!!!
01-10-2007, 06:55 PM
Booting Nicotine!!
^^^ agrees with crazyforever
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
01-10-2007, 06:57 PM
TechTin.com
Originally Posted by abtom
here r some tips:
I dont think number of OS installed has anything to do with system performance.
01-10-2007, 08:39 PM
Installing more than 2 os doesn't degrade system performance.It's just a myth.
01-10-2007, 08:42 PM
Commander in Chief
What he probably meant was that Dual-Boot timeouts slow your PC down.
01-10-2007, 08:48 PM
^u mean the 30 sec before the default os is started?BTW one can always select the required os to cut down the time.
