Old 30-09-2007, 12:24 AM   #1 (permalink)
napster007's Avatar
Default Internet Explorer Problem
i'm facing a tiny problem with my ie7. i recently installed windows xp sp2 on my system... ...and it seems that where ever i tick the "REMEMBER ME" option it dosen't recongize me next time i visit the website. same thing happens with this forum too. its a simple thing i know but i cant apparently i can't find the opion. please help me out.
thanks
does no one know how to fix it?????????????
napster007 is offline
Old 30-09-2007, 11:54 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Internet Explorer Problem
Try This :
How to Force IE to save passwords...again !
With AutoComplete 'on', your IE prompts you whether to save the logon name/password or not. If you select 'No' your decision is recorded in the registry and you wont be prompted again ! But what if you change your mind ? Here is how you can reset.
Run Regedit > HKCU\Software\Microsoft\Internet Explorer\IntelliForms\Storage2 > See the left pane > select the Storage2 key > Click File > Export > Save the key to a safe location as SavedPassword.reg Now in the right pane, select all values & click Delete.
Now in IE, go to the site whose password you want to save. Fill in your details and then click to submit the data. Now when IE asks if it should remember your password, click Yes.
Come back to the Registry Editor. Click File > Import > Select the file you saved as SavedPassword.reg > Click Open to merge the saved data into the registry.
This way you will also have saved your previously saved passwords as well as the one you just created.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Internet Explorer Problem sudipapd Software Q&A 7 27-09-2007 03:38 PM
Internet Explorer Problem sudipapd Software Q&A 2 12-08-2007 01:20 PM
internet explorer 7 problem saurabh kakkar Software Q&A 3 12-06-2007 11:32 PM
Problem with Internet Explorer sainit Software Q&A 3 24-09-2006 06:48 PM
Internet Explorer Problem in Win XP SP2??? go4saket Software Q&A 6 20-10-2005 12:49 PM
- by Niilesh
