Old 27-09-2007, 01:01 PM   #1 (permalink)
Default task manager and system registry is not opening
hi,
i have the problem like that my system registry and task manager has not been working.when i press the ctrl+alt+delete and the error shows the task manager has been disabled by your administrator.when i try to open the registry,it didnt show any errors.but one beep sound has been heared from my headphones.then i went to the gpedit.msc and then disabled the ctrl+alt+del options.then i try to open the task manager it will appears and immediately it will disappears.what can i do?please help me?
thecreativeboy is offline
Old 27-09-2007, 01:13 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: task manager and system registry is not opening
To enable task manager go here
Third Eye is online now
Old 27-09-2007, 11:31 PM   #3 (permalink)
sumeetindia's Avatar
Your PC is infected with virus
Download and install a good antivirus like NOD32 trial
Or AVG free
Then Update it
Restart the PC in safe mode
Connect all the flashdrives/External Hdds/Storages
Scan your full system including the external drives (If using NOD32 ->start NOD32 ->select all the drives ->click "scan and clean"
After the cleaning is done restart the PC in normal mode
downlaod this tool ->http://download.sergiwa.com/security/RRT.exe
Start the tool and enable the regedit /folder options/ Task manager
Sumeet
www.fultoomobile.com - Free Hindi Ringtones and mobile wallpapers
sumeetindia is offline
Old 28-09-2007, 12:32 AM   #4 (permalink)
slugger's Avatar
almost ALL newly registered members have started a thread to find a solution to solve this problem without searching the forum
and yet millions of patient solutions they have recieved on this forum
and here u start 1 more thread
SEARCH THE FORUM BEFORE POSTING
REPORTIN
slugger is offline
Task Manager = not opening! sujoymukherjee QnA (read only) 9 20-07-2007 09:11 AM
task manager 047 Software Q&A 7 16-02-2007 10:43 PM
Help with task manager rohit_z2k QnA (read only) 6 11-04-2005 01:37 AM
setting priority of a task in task manager zoom QnA (read only) 4 23-02-2005 12:11 AM
- by Niilesh
