I recently upgraded the RAM of my Presario SR 1930 IL (2.8 GHz, 512 MB as installed). I took a 1 Gig Zion Ram and put into the second slot.
While installing, we found that when both RAMs are there, it reads only the original 512 MB RAM. BIOS shows second Memory Bank "not installed". If we removed the original RAM, it read the new RAM fine.
After some effort, it read both RAMs. What we did was: we went to BIOS and "saved settings" and then exited and then shut down and rebooted and then it showed both RAMs.
Then again sometimes it showed only one RAM when I came back from office and checked while some family members were using it. I shut down and again started and it read both the RAMs.
Now I am seeing that it is consistently not reading the second RAM at all. Shut down, restarted, went to BIOS and "saved settings". Nothing seems to work.
Can someone help ??
