Old 25-09-2007, 11:43 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Unhappy My system is infected with spyware!!
How to remove it? I have Spybot - Search and Destroy. It detects 2search as a spyware in my machine, tells me to remove it, I remove it, but it comes again. . Spybot detects the entry in C:\documents and settings\username\local settings\temp\ibho.log. It tells me it is a tracking cookie pointing to some 007guard site.
I also installed ad-aware but it is incapable of removing it. It does not detect it even.. Am I doing something wrong? Is there any way to remove this annoying piece of spyware? It is getting on my nerves.
Any help would be highly appreciated. Thanks.
I use WinXP with SP2 and with Symantec Antivirus Corporate edition and Cyberarmour personal firewall with all the latest definitions. I am more worried as this is my work laptop.
I have no idea how it got installed.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 25-09-2007, 11:47 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: My system is infected with spyware!!
allways turn of the system restore when you try to scan for Spyware or Virus...
http://www.chotocheeta.com/2007/09/1...ystem-restore/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-09-2007, 12:51 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
1) turn off system restore
2) Update your antivirus and anti aspyware.
3) Boot in safe mode.......do full system scan with antivirus and anti spyware.
4) If possible do scan at startUp....or do online scan.
ravi_9793 is offline
Old 26-09-2007, 04:49 AM   #4 (permalink)
Manchester United
Smile Re: My system is infected with spyware!!
As this is a work computer and I have specific permissions set by the network administrator, I could not turn off system restore. But I have administrative rights. But I found a alternate way around, should have thought of it much earlier.
I booted in safe mode, used system restore to restore the system to an earlier date, a date earlier than what I suspected the system got infected.
Thanks for your replies people.
Old 27-09-2007, 04:40 AM   #5 (permalink)
download superantispyware and run it after updating....100% spywares will be removed..coz one of my friend works for DELL and they use this to remove spywares
'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
hyde is offline
Old 27-09-2007, 09:29 AM   #6 (permalink)
Is actually a real word..
Dell In India? or in NA? I see they moved up from the Spysweeper (which I hated with a passion!!!)
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
My system is infected with adware/pornware ilugd Software Q&A 38 12-08-2007 11:25 PM
stisvc.exe infected with virus/spyware CadCrazy Software Q&A 8 29-07-2007 11:13 PM
Infected by Spyware/Keylogger nirubhai Software Q&A 7 29-05-2007 12:51 AM
System is infected with Trozan.zlob sainit QnA (read only) 2 03-07-2006 08:53 PM
help system infected with Win32.pinfi virus. Mangal Pandey Software Q&A 2 24-08-2005 12:56 PM
- by Niilesh
