Old 25-09-2007, 05:40 PM   #1 (permalink)
Default Two OS problems!!!
hi guys i'm getting some weird problem in my winXP sp2
Problem 1)
i'm getting some problem to open certain websites from my PC. Like i can open a website which i use to see my internet account usage, but when i enter login and user name and try to enter the page reloads again. I can open metacafe.com but i don't get search box as well as if i select any category, still it doesn't open the tay category and remains as it is. I tried with firefox with IE tab as well as iE 7 but the same problem persists. I tried by unstalling my antivirus but still it remains same. I don't have any fire wall installed. I tried with windows firewall off but same result.Does anyone has any suggestion.
Problem 2)
Whenever i oprn my search box from start i can open it but doesnt have serch boxes to enter my search. i'm attaching a pic so u get a better idea.
Even folder options doesn't open.
pls help me to solve this problem
The Nilay is offline
Old 25-09-2007, 05:45 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Two OS problems!!!
virus
this might help u
Spywares
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-09-2007, 05:48 PM   #3 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
1) Um, Have you by any chance disabled JavaScript? It mostly seems like a Javascript Problem.
2) Looks like a Virus problem! Which Antivirus do you use? Norton? If yes, kindly update it to the latest version OR uninstall it and install lastest Kaspersky/NOD32 to scan and remove all the malware.
Edit: Oops! aravind_n20 beat me to it!
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 25-09-2007, 06:02 PM   #4 (permalink)
i have nod32. I scanned the whole PC. deleted all the infections. Still this is happening. Java plugin is enabled.
Old 25-09-2007, 06:40 PM   #5 (permalink)
[xubz]'s Avatar
No No! Not Java Plugin! its JavaScript! (Please don't confuse the two! JS != Java!)
It can be enabled in the Browser Settings.
Since you said you cleaned your infections, then I think some irreversible damaged files have been left back? (i think so).
Better get XP Installation CD and run System File Checker.
Type sfc /scannow in Start-> Run
[xubz] is offline
XP got problems i4gotmyid Software Q&A 5 31-12-2006 07:48 PM
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
OS problems .......... please help!!! Mohnishgs Software Q&A 4 14-05-2006 12:24 AM
Help: 3 Problems Monster_AMD QnA (read only) 3 24-08-2005 05:31 PM
Problems with MGS DKant Gamerz 9 28-03-2005 08:34 PM
- by Niilesh
