Old 24-09-2007, 12:04 PM   #1 (permalink)
Default Lohgitec LED series 300 GB Harddisk problem
Hi frndz....
I have logitec LED external HDD of 300 Gb bought it from japan 6-7 months ago..... dont have waranty bills with me now.....
from last 1 months it giving problem like...whenver i format it it works fine for 2-3 tiomes....next time it just shows HDD got couruppted...and file system it shows as RAW.
Last time i have lost my all backup of lappy and system.
PLease suggest me whats the problem with my HDD.
will it be repairable....I dint partitioned it....should i ??
prafulltcs is offline
Old 24-09-2007, 12:12 PM   #2 (permalink)
shantanu's Avatar
Default Re: Lohgitec LED series 300 GB Harddisk problem
Yeah First of all ! use a Good Disk Management tool and Repartiton your drive.. if still the problem persists.. then Zero Fill it (fully) and then partition it and install Windows.. it will cure the problem. and you can also try to Update the MBR..
shantanu is offline
Old 24-09-2007, 12:25 PM   #3 (permalink)
Hey frnd shantanu... will u please tell me which sw to use partition it and format it..
Is this problem exists due to ...lappy has NTFS and systemhas fat32....and access via both one by one creates problem??
Do you know a good recovety s/w ?? i have used a lot other but takes long time and scans only for images/docs...
Old 24-09-2007, 12:28 PM   #4 (permalink)
shantanu's Avatar
no this problem cant be of NTFS or FAT32..both work cooly with each other..
Partition Magic is a nice software... Google it ..
search this forum for Recovery options..
shantanu is offline
Old 24-09-2007, 12:35 PM   #5 (permalink)
Hey Thanx frnd...
Harddisk Problem Plz help aquafusion Hardware Q&A 1 01-09-2007 08:09 PM
portable harddisk problem manishjha18 Hardware Q&A 1 19-08-2007 10:34 PM
Problem in Harddisk,Somebody please help!!! anand1712 Hardware Q&A 8 01-06-2007 04:53 PM
harddisk problem sidcool Hardware Q&A 2 13-01-2006 08:24 PM
HArddisk Problem prashantbhat25 QnA (read only) 4 30-12-2004 11:02 PM
- by Niilesh
