Old 23-09-2007, 05:47 PM   #1 (permalink)
bajaj151's Avatar
Question Booting Problem !!!
When I switch on pc.....it shows an error
"Reboot & Select Proper Boot Device
or Insert Boot Media"
Then I press ctrl+alt+del combination and then it boots properly...
I am using Vista OS on my SATA hdd...
And I checked my bios for first boot device...and its HDD...
How can I get rid off this problem ????
Thanks....
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 23-09-2007, 06:47 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Booting Problem !!!
Is this ur new problem??Have you made any change inside your cabinet.
If NO, than:
Most possible reason is "your hard disk is faulty".Try another hard disk (take from ur friend)..and than reboot ur PC. In this case, your PC should work fine.
ravi_9793 is offline
Old 23-09-2007, 06:54 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
+1 for above reply
Gigacore is offline
Old 23-09-2007, 07:47 PM   #4 (permalink)
a_tif's Avatar
also check hard disk's power cable and sata cable
a_tif is offline
Old 23-09-2007, 09:08 PM   #5 (permalink)
bajaj151's Avatar
I think...its cable problem.....will check it ...tomm.
Old 23-09-2007, 10:37 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
and yeah..must post the result.We will also learn something.
Old 23-09-2007, 11:03 PM   #7 (permalink)
bajaj151's Avatar
okizz...I will
xp booting problem sharma_atul85 Software Q&A 3 06-09-2007 05:54 PM
Problem booting XP opokharel Software Q&A 1 09-02-2007 12:45 AM
booting problem amey kerkar Software Q&A 5 30-07-2006 03:36 PM
Xp booting problem. sagar_coolx Software Q&A 3 30-04-2006 12:08 AM
BOOTING PROBLEM AVESH NARANG Software Q&A 5 16-02-2005 10:32 PM
- by Niilesh
