Old 23-09-2007, 01:56 AM   #1 (permalink)
Default Audio boost Vista Vaio
Hi,
I have sony vaio with Vista installed. I find the movies and audio files and in general the windows default sounds too very low for a maximum volume. I have installed Vista codec pack. I have tried boosting in the AC3 filter but it only works for Ac3 coded movies (i guess or i dont feel a difference really). Are there any plugins or codecs for audio amplification?
thanks,
legolas
legolas is offline
Old 23-09-2007, 03:19 AM   #2 (permalink)
slugger's Avatar
Default Re: Audio boost Vista Vaio
use winamp's preamp feature from its eq win
slugger is offline
Old 23-09-2007, 07:04 PM   #3 (permalink)
i dont use winam for movies. I use vlc or windows media player 11. i tried using ffdshow audio decoder and it works. But at high volumes the volume starts to screech... it becomes very noisy. so the thing is, i need a plugin or decoder not for the software, but for preamplifying for any1. more like a codec plugin or something like that... hope i explained right??
legolas
legolas is offline
Vista Audio Driver for DELL Gx 620 gunda_26 Software Q&A 2 02-05-2008 12:50 PM
5.1 audio ON VISTA NOT WORKING. lavi87 Software Q&A 1 08-08-2007 11:57 PM
Windows Vista For RAM BOOST... Abhishek Dwivedi Software Q&A 21 09-07-2007 11:57 PM
Vista audio drivers AD1986A narangz Hardware Q&A 3 23-05-2007 01:59 PM
Vista Audio problem? shashank_re Software Q&A 12 21-11-2006 11:37 PM
- by Niilesh
