Old 22-09-2007, 10:00 PM   #1 (permalink)
Cool G5's Avatar
Exclamation Internet explorer encountered a problem....
I formatted my system recently.I kept one partition of my HDD while formatting intact(F:\).
Now whenever i open F:\ it gives
"Internet Explorer has encountered a problem & needs to close.We are sorry for inconvenience."
Error signature:
AppName: explorer.exe AppVer: 1.1.0.47 ModName: oleaut32.dll
ModVer: 5.1.2600.2180 Offset: 00004cc5
When i click close the window(F:\) doesn't close though.
Also now every partition gives the same error when i open it.
And when i open opera(or any other app) & browse to (F:\) opera crashes.
Also now randomly opera crashes while browsing.I use NOP to browse net on pc.
Plz help me get rid of this problem.
Cool G5 is offline
Old 22-09-2007, 10:37 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Internet explorer encountered a problem....
To resolve this problem in Internet Explorer, follow these steps:
1. Quit all programs that are running.
2. Click Start, and then click Run.
3. Type: regsvr32 urlmon.dll and then click OK.
4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.
If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below):
• Shdocvw.dll
• Actxprxy.dll
• Oleaut32.dll
• Mshtml.dll
• Browseui.dll
• Shell32.dll
If you have a retail version of XP you can run sfc /scannow via start/run
This will repair all system files (including IE). You will need to insert your disk.
http://www.d-a-l.com/help/showthread.php?t=31525
Life is as complicated as you say it is.
shady_inc is offline
Old 23-09-2007, 12:28 PM   #3 (permalink)
Cool G5's Avatar
^Let me try.
Cool G5 is offline
Old 24-09-2007, 11:02 PM   #4 (permalink)
Cool G5's Avatar
It's didn't worked.
Cool G5 is offline
Old 27-09-2007, 01:13 PM   #5 (permalink)
Cool G5's Avatar
Bump.
My other apps(opera,gtalk) also crash giving me the same error.
Cool G5 is offline
internet explorer problem msnways1 Software Q&A 1 15-09-2007 02:45 PM
Internet Explorer 7 problem sanbarta Software Q&A 2 09-06-2007 08:39 PM
Please Help Me Explorer.exe has Encountered a problem and need to be close. bhutbhut Software Q&A 7 10-03-2007 11:17 PM
Internet Explorer 6.0 Problem- Plz Help !!! lovemeall26 Software Q&A 2 27-01-2007 12:47 PM
Problem in Internet Explorer aravind_72 Software Q&A 2 11-01-2006 06:36 PM
- by Niilesh
