Exact Problem With me.
Win XP SP-II Installation Problem
Still my problem is not solved. My system is running with only XP pro. Even the Mother Board Mfg company MSI could not solve my problem. Lastly they gave me suggestion to go to MSI Service Center to check the Mother Board. Which is not possible for me as their Service Centre is located at New Delhi.
mayhemabhi
As per MSI's recommendation, you may do one thing that is you check your SMPS, if it is below 300 Watt You may try installation with a SMPS of above 300W.
Note : Before doing that please go through your MB mannual or MB MFG's company sites. You may also contact the techinal support team of the company.
