21-09-2007, 09:56 PM
audio driver-intel d945gcnl
i bought a intel d945gcnl motherboard.i installed the sound drivers but they do not work.can ne1 tell me wat i shud do
21-09-2007, 11:02 PM
Re: audio driver-intel d945gcnl
if u r not able to hear any sound, den probably d Windows Audio service is disabled (dunno abt XP but in 2003 it is disabled by default)
enable it and put to Automatic
it can b done thru
Run->Services.msc
press enter and u will get d list of services
22-09-2007, 07:12 AM
@cheeta
how do dwonload adn install KB888111,there is nothing in that link u gave me
22-09-2007, 07:34 AM
Rebooting
There are 2 ways for it...
1. Run Windows Auto Update from your PC... Windows will detect your Hardware and will provide you the patch... (Recomended)
2. If you are unable to run Auto update from the same PC then please contact microsoft using the given link to request and obtain the update (Note its free support)
rebooting
ChotoCheeta.com
22-09-2007, 05:58 PM
@choto cheetha
i downloaded and installed from the link u gave me,the problem iss till there.any other solutions
22-09-2007, 06:03 PM
Rebooting
After you have installed the Patch u should once again run the Driver Setp up  did u run it ??
rebooting
ChotoCheeta.com
22-09-2007, 06:10 PM
wait i'll uninstall the drivers and reinstall them
and for som reason the realtek thing shows this even though my front jacks are not connected
(ps i have attatched the pic)
22-09-2007, 06:17 PM
dude i reinstalled the drivers.they dont work
22-09-2007, 08:38 PM
wat is d exact problem u r facin?
is it giving u sum error message wen u try to play sum sound or is it that the media player being used shows that the track is being played but you r not able to hear any sound?
aslo remember that the line-out jack of the soundcard is green in color
u must put te jack in that socket to hear any sound
check the volume ctrl to ee if either Volume control or wave balance is not muted
if it is then u will not b able to hear the sound
22-09-2007, 10:18 PM
@slugger
i have installed the audio drivers and the device manager shows they r working properly but there is no sound.thats the problem.i have also checked all connections
22-09-2007, 11:06 PM
Rebooting
In I think you should take the board back to Vendor for warrenty support
rebooting
ChotoCheeta.com
16-10-2007, 02:00 PM
Hi,
I too have the same Audio driver problem. My motherboard is Intel D945GCNL. The OS is Windows XP with SP2. I had downloaded the Realtek driver which was available in Intel website. Still the driver is not installed. In Device manager there is an yello exclamatory mark on the Audio Driver. Is there anyother batch which needs to be run? Please help me.
04-12-2007, 08:59 PM
The driver install package from Intel only extracts the files for install. Once you browse to where the files were extracted, run the setup program. That will install the Realtek HD Audio Control panel, the HD audio driver and KB888111. Raviramgopal definitely found an issue. I assume that he is not using HD 5.1 speakers. If you go into the 'Windows' Audio Control panel, not Realtek's. Click properties and show front speaker you will notice the volume is turned all the way down. Crank it up and you will have sound with a 2-channel analog speaker system. Someone crossed their I's and dotted their T's somewhere along the way!
05-12-2007, 08:29 AM
Solved the problem at last with the help of a Servicing personnel. After the OS is installed, once we are installing the Audio Driver, the found new hardware wizard pops up, press cancel for the wizard as the Driver CD will directly run a batch and then install the driver. If we continue with the wizard, the batch is not run and the driver will never get installed unless we reinstall the OS.
23-01-2009, 01:59 PM
i am having the same problem help me "senthilje"
23-01-2009, 02:07 PM
FunkyGarzon,
Once you install the OS , and install the audio drivers, there is a popup which comes and asks for the source of the driver. Never point to the CD. Just insert the cd and wait for sometime. the installer itself would go and take the path and install it. If you click browse and point the CD, the updates are installed first and the only way to get through that will be by reinstalling the OS. Please buzz me if you need any more clarification
23-01-2009, 03:37 PM
senthilji,
thanks for the quick reply
Actually i lost my driver cd of this mother board, can you pls pls upload that driver cd for me pls i am in need of that ....i also tried to download many driver from the intel site but no use ,i thing if you sent me that cd in some image format i can do like your above inst
23-01-2009, 03:58 PM
#19 (permalink)
Sorry Dude. I dont have the cd too. Should search it in my archives and I am away from home. I cant guarantee that I will be able to get it within a week even.You can check for the updated drivers in Intel website.
23-01-2009, 04:09 PM
#20 (permalink)
senthilje ,
pls try as much as possible..pls
else pls try to send your audio driver setup by uploading in any site like rapidshare,megaupload,ext ..pls ....i am in need of that....cos my audio is not working
23-01-2009, 04:14 PM
#21 (permalink)
Originally Posted by funkygarzon
sentilije ,
I would suggest you to download it from intel website or you can check www.phazeddl.com.
23-01-2009, 04:23 PM
#22 (permalink)
senthilji,
can you pls send me full download link .....of www.phazedll.com cos it is new to me
senthilje,
you will be having your audio driver right ...pls upload them in the www.rapidshare.com ...thank you for the help
senthilje ,
if you want i will give my www.rapidshare.com acc for free ..pls help me my yahoomessenger id is funkygarzon@yahoo.co.in contact me
Reason: Automerged Doublepost
23-01-2009, 04:40 PM
#23 (permalink)
Buddy,
I have the source files in the original cd. cd is in my home and I am working away from home. Best is to reinstall OS and insert the CD. Download the latest audio driver from Intel website and burn it in a cd dude. I dont see what is your problem in downloading it from Intel and burning it in a CD.
23-01-2009, 04:58 PM
#24 (permalink)
senthilje
i reinstalled the os and i also installed the new audio driver which download from intel...but still sound is not coming ...pls i am in critical position
26-01-2009, 09:13 AM
#25 (permalink)
senthilji,
when you reach the home pls try to upload mother board cd.....but god solved my problem .....i just googled
