Old 20-09-2007, 04:41 PM   #1 (permalink)
Default registry problem..!
hello guys..!
i make a few changes in the registry, they remain till the time i shut down my pc....as soon as i restart my pc, the changes i made do not exist nemre..!!
pls help..!
thnks in advance..!
manan
magneticme200 is offline
Old 20-09-2007, 06:43 PM   #2 (permalink)
ayush_chh's Avatar
Default Re: registry problem..!
what kind of changes do you make in the registry??
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 20-09-2007, 09:18 PM   #3 (permalink)
i have a virus called maskrider2001.vbs in mah pc..!!
it does nt allow me to double click open my drives...if i double click any drive is says...""cannot find script file C:\maskrider2001.vbs""
though i can open my drives by right clicking open..!!
i searched the registry fr maskrider...and watever entries i found i deleted them..!!
wen i delete them the drives work fine till the time i dont restart my pc..!!
wen i restart fr some purpose thn those entries come again and the drives again start to behave the same way..!!
i find the maskrider in the following locations..
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\
Explorer\MountPoints2\{56164031-dd6f-11db-b156-806d6172696f}\
Shell\AutoRun\command
Explorer\MountPoints2\{56164033-dd6f-11db-b156-806d6172696f}\
Explorer\MountPoints2\{56164034-dd6f-11db-b156-806d6172696f}\
wat do i do????
Old 21-09-2007, 02:07 PM   #4 (permalink)
Yalam
delete all autorun.inf and this vbs file(if exists) from the root of every drive(even your usb drives connected). They may be super hidden so first unhide them. Run msconfig from RUN and under STARTUP uncheck all traces of this virus. U can also open services.msc from RUN and look for any traces of this virus and stop it and set its startup to Disabled. Also search for the vbs all over C drive and delete them before restarting . You can also turn off Autoplay feature from Gpedit.msc if it exists upon right clicking your drives.
Yavin is offline
Old 21-09-2007, 02:20 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
1)Turn off system restore.
2) Scan your computer using a good updated antivirus
3) scan your computer using two updated antispyware.
Best way...do online scaning..and scan while booting .
Find some online scan options here:
http://www.techiehome.org/viewtopic.php?t=512
ravi_9793 is offline
Old 21-09-2007, 03:32 PM   #6 (permalink)
one of my frnd is also infected by the same which mentioned above....
he is not able to open drives by double clicks.......
it may be a virus......?
yes he was infected by virus so i gave him kaspersky, and he cleared all the virus but still he is not able to open drives by double clicks.....
so in this case what should he do......? he does not have internet connection.....
qadirahmed is offline
Old 21-09-2007, 03:46 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
All ur solution is here:
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
Old 21-09-2007, 04:19 PM   #8 (permalink)
thx for the link dude......
Old 21-09-2007, 08:52 PM   #9 (permalink)
ayush_chh's Avatar
yes u must delete autorun.inf files from all ur drives...they may be system files so goto Folder option and under view tab select show all hidden files , uncheck hide system files....you will now be able to see those files
Infected Registry Problem Ecko Software Q&A 1 10-06-2007 09:48 PM
Registry problem in windows XP bipshee1234 Software Q&A 4 25-04-2007 08:01 PM
Windows Registry problem.......... uchiha.sasuke Software Q&A 14 23-02-2007 08:52 PM
Registry Writing Problem aditya.shevade QnA (read only) 5 16-09-2006 12:19 PM
registry problem iinfi QnA (read only) 5 07-02-2005 01:14 AM
- by Niilesh
