Old 20-09-2007, 02:04 PM   #1 (permalink)
AFK
thewisecrab's Avatar
Question mcafee not uninstalling
hi guys i had mcafee on my laptop(dont ask) i also have a certain icon called mcafee viruscan now when i try to uninstall mcafee it says to first remove all its services (uninstall all its services) but i cant find any of its services how do i remove this cr@p???? thanx in advance
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 20-09-2007, 02:36 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: mcafee not uninstalling
I also had mcafee few days before..but uninstall it without any issue.I was having complete Mcafee security suit
ravi_9793 is offline
Old 20-09-2007, 02:37 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
You can try the Mcafee Uninstaller.It's a shareware,unfortunately. .But free to try for 30 days.
Life is as complicated as you say it is.
shady_inc is offline
Old 20-09-2007, 02:46 PM   #4 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
I got the problem first u need to disable Macfee Services Like Msshield etc
from Task manager then u can uninstall
saurabh kakkar is offline
Old 21-09-2007, 07:49 PM   #5 (permalink)
AFK
i tried but it didnt help
Old 22-09-2007, 05:24 AM   #6 (permalink)
Is actually a real word..
Mcafee should have a removal tool, if not you're gonna have to jump to the registry and remove main components in there then it should come out....
here try this it is mcafee's removal tool.... www.mrtool.notlong.com
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Uninstalling OS....??? Pragadheesh QnA (read only) 2 11-11-2006 09:06 PM
Uninstalling Outlook kumarn_2004 Software Q&A 2 23-09-2006 02:55 PM
OS Uninstalling problem Ishan QnA (read only) 8 24-09-2005 11:32 PM
Uninstalling Win XP cvvikram Software Q&A 7 10-06-2005 11:46 AM
uninstalling OS?? mario_pant QnA (read only) 6 14-04-2005 10:41 PM
- by Niilesh
