Old 19-09-2007, 10:47 PM   #1 (permalink)
gurujee's Avatar
Default problem: slow start/restart and shutdown
I have a P3,256ram,1.10ghz, XP sp2. I have formatted my pc recently, but now the start/restart and shutdown is taking ages. But before i had media centre but was not taking so many time....what's the prob ????
and also my pc is getting hanged between 2-3hours, especially when browsing net. sometime also when working without net it gets hanged.
anyone knows about its solution ?
gurujee is offline
Old 19-09-2007, 11:24 PM   #2 (permalink)
slugger's Avatar
Default Re: problem: slow start/restart and shutdown
first Disable all Services that you do not need
Start->Settings->Administrative Tools->Services
if u dont wan2 do it manually then i suggest u use GameXP
it will do a lot of speed optimisations
it is a little conservative when disabling services, but still does a decent job
u must also delete all d unnecessary startup entries
use RegSeeker 1.55
u can do so thru the Startup entries section
u can also use msconfig, but i like RegSeeker 1.55 better
there r literally tonnz of tweaks u can do 2 speed up ur OS, but these r d 2 basic things u must do
it seems that ur sys is overheating
mite wan2 open ur cabinet to c if there is any obstructions in d airflow around d processor
an also if d air vents of ad cabinet r cloged or not
u mite also wan2 consider applying an new layer of thermal grease to d processor, since P3s are almost 7yr old
slugger is offline
Old 20-09-2007, 01:14 AM   #3 (permalink)
gurujee's Avatar
thanks bhai, let me try those. i will let know what happens ?
and where i can apply that thermal grease ??
gurujee is offline
Old 20-09-2007, 01:16 AM   #4 (permalink)
slugger's Avatar
thermal grease is applied between the processor and the heatsinks
BTW wats ur system/CPU temp when it hangs?
slugger is offline
Old 20-09-2007, 01:20 AM   #5 (permalink)
gurujee's Avatar
i mean at my hardware vendor, i can apply that ?
sorry, i dont know how to check that temp :redface:
gurujee is offline
Old 20-09-2007, 08:30 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
1) First step check for virus.
2) second: read this article:
MASTER TUTORIAL: Make Your Windows XP Super Fast !!!
3) Regarding shutdown:
http://www.techiehome.org/viewtopic....r=asc&start=15
ravi_9793 is offline
Old 20-09-2007, 09:01 AM   #7 (permalink)
Distinguished Member
anandk's Avatar
search here for : Start Run Faster
you will get 2-3 good threads here on how to make windows start run shutdown faster.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 21-09-2007, 05:24 PM   #8 (permalink)
slugger's Avatar
u can use Hardware Monitor 1.6 Beta to check your system/CPU temp
(assumn ur mobo's got temp sensors, my P3 had )
slugger is offline
Old 21-09-2007, 06:52 PM   #9 (permalink)
gurujee's Avatar
i tried but it said
"couldnot open DriverLINX driver"
gurujee is offline
Old 21-09-2007, 06:56 PM   #10 (permalink)
hey man go to run type MSCONFIG, in that go to services tab,disable all the service except microsoft windows,and go to start up tab,disable unwanted startup options........
u r done,now check
plybz18 is offline
Shutdown instead of Restart lahratla QnA (read only) 4 23-10-2005 12:02 AM
no shutdown/restart/ctrl+alt+del.. pls help. urgent!!! :( legolas QnA (read only) 7 01-10-2005 06:04 PM
Shutdown ur pc to restart it !!!!!!! abhi1234 QnA (read only) 5 30-04-2005 07:44 PM
Fast restart & shutdown Neil QnA (read only) 4 30-12-2004 12:05 AM
shutdown = restart simplegeek QnA (read only) 1 28-11-2004 07:11 PM
- by Niilesh
