Old 19-09-2007, 07:32 PM   #1 (permalink)
Yoda's Avatar
Default Unnecessary message while logging on...Please help me solve this?
Hi Friends,
Hi friends,
I've a modified version of Windows XP Pro with SP2. I want my system to logon to XP as soon as possible. So I want to enable Auto Logon in my Windows XP Pro SP2 on the Administrator Account.
I made somehow the Auto Logon but I get a lot of messages when the system auto logons..Please someone solve this problem. And I'm also not getting the Welcome Screen.
what is ctfmon (C:\Windows\system32\ctfmon.exe) which sits in the starup. Sould I enable it in the startup or uncheck it in the stratup.
What is sstray in startup....Should I check it the stratup or uncheck it.
Should I enable ctfmon and sstray in the stratup.
Yoda is offline
Old 22-09-2007, 06:28 PM   #2 (permalink)
Smile Re: Unnecessary message while logging on...Please help me solve this?
go into the RUN in the windows startup n punch in "msconfig"
then change your loggin' in options...this should help u out.
changin...i.e.enabling or disablin' system32 programs is a strict no-no if you dont hav an idea about them
hope n a li'l bit of sugar...
its_me_jeet is offline
Old 22-09-2007, 06:40 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Unnecessary message while logging on...Please help me solve this?
thats coz you've the verbose status enabled. to disable it follows these steps:
On a stand-alone computer or a single computer
If you are using a stand-alone computer or if you want to enable verbose status messages on only one computer, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type gpedit.msc, and then click OK.
3. Expand Computer Configuration, expand Administrative Templates, and then click System.
4. In the right pane, double-click Verbose vs normal status messages.
5. Click Disabled, and then click OK.
6. Close Group Policy Object Editor, and then click OK.
infra_red_dude is offline
logging in logging off ondemandemails Software Q&A 2 06-02-2007 09:46 PM
how to delete unnecessary entries from start button Shasta Software Q&A 15 06-02-2007 05:46 AM
Logging sms ankush Mobiles and Tablets 1 18-09-2006 02:05 PM
logging in a LAN gramesh Networking 8 25-05-2006 11:44 PM
- by Niilesh
