Old 18-09-2007, 10:41 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Help Win XP SP2 installation
I have a motherboard (name exactly not known but there is written VEGA, a BSl group limited , Prescott Ready) I think it is VEGA intel chipset. 512 MB ram . Earlier I have installed XP SP1 and it work fine then I install XP SP3 it also work fine but now I am facing problem Adobe CS3 is not installing in SP3. So I have delete the C: partition and format it as NTFS then try to install XP SP2 but after copying file when window restart to begin the installation process it get's hanged. I have tried several time deleting C: , formatting again and again but no sucess.
Is this a BIOS problem or Motherboard Problem Plz tell me Help.
Kaushal Hiwarkar is offline
Old 18-09-2007, 10:54 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Help Win XP SP2 installation
Revart Back to Windows XP non SP1 / SP2 Installation Source... install just Windows XP non SP installation then after installation try to install SP1 / SP2 see what happens...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-09-2007, 06:27 AM   #3 (permalink)
It's a BIOs setting problem, I have disabled "Legacy control L1 and L2" now I am able to install XP SP2 but now the problm is with speed. Installation process is very slow I have Intel P4 and 512 ram
Old 19-09-2007, 06:54 AM   #4 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
offtopic when did sp3 came out?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 19-09-2007, 11:43 AM   #5 (permalink)
Rebooting
SP3 is not out, its the Pre Public Beta of the Service Pack which came out to a Limited number of Beta Testers and right now its available on MSDN too
rebooting
ChotoCheeta.com
HELP XP installation raina_rocks Software Q&A 13 30-07-2007 12:48 PM
nsu installation help rksingh Mobiles and Tablets 8 10-02-2007 07:24 PM
K3b Installation help....? LEARNER_LEARNER Open Source 8 18-12-2006 09:37 PM
C++ installation pradeep Programming 1 31-12-2005 01:22 PM
WIN XP installation... //siddhartha// Software Q&A 14 17-02-2005 06:30 PM
- by Niilesh
