Old 18-09-2007, 12:05 AM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Problem msconfig, WMP10, Volume Icon
In my system WinXp SP2 msconfig is not running, Volume icon is not showing in systray although there is sound in my system. I have checked volume property,control panel etc and Window
Media Player 10 is not opening. Plz help
Kaushal Hiwarkar is offline
Old 18-09-2007, 03:29 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Problem msconfig, WMP10, Volume Icon
msconfig not running means ?? can u be please little more technical ?? like what error do u get whne u try to launch the msconfig ??
about sound problem, try and reinstall the sound drivers for the sound device you have
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 18-09-2007, 08:37 PM   #3 (permalink)
slugger's Avatar
2 get d Volume icon back in d task bar follow dis path
Start->Settings->control Panel->Sound and Audio Devices->Volume(tab)->Place Volume icon in the Task Bar(check)
to run MSCONFIG just follow
Start->Run
type msconfig and press ENTER
hopefully it will open d msconfig window
if it says file missing or sumthin den download MSCONFIG.EXE and run it from wherever u extract it
slugger is offline
problem with vista msconfig! soumya Software Q&A 9 28-05-2007 08:05 PM
Editing tags using WMP10 bizzare_blue Software Q&A 3 19-11-2006 03:33 PM
WMP10 direct_2d QnA (read only) 10 15-10-2005 05:01 PM
burning audio cds with WMP10 setharsh QnA (read only) 2 18-07-2005 09:06 PM
MSCONFIG is not running in Win XP ( Start> Run > Msconfig ) imprince Software Q&A 3 14-12-2004 08:19 PM
- by Charley
- by tv6952
