| Forum |
#1 (permalink) |
Be Healthy, Keep Smiling
Unistalled Adobe CS2 and try to install CS3 but I am getting following Error { Setup Error : Setup has Encountered an Errorand cannot continue. Contact Adobe customer support for assistance The Window Installer Service could not be accessed. This can occur if you are running Windows in safe mode, or if the windows Installer is not correctly installed. Contact your support personnel for assistance } I am not running in safe mode. Now when I try to install CS2 I am getting following Error: { Window Installer: The Window Installer Service could not be accessed. This can occur if you are running Windows in safe mode, or if the windows Installer is not correctly installed. Contact your support personnel for assistance } Now I dont have Cs2 nor Cs3. Plz help One more thing msconfig is not running, Volume icon is not showing in systray I have checked volume property, and Window Media Player 10 is not opening. |
#2 (permalink) |
Rebooting
May be you need to run a Command,
in Command promt go to location C:\Windows\system32 and type in regsvr32 jscript.dll
rebooting ChotoCheeta.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Adobe cs3 installation | baiju | Software Q&A | 11 | 09-08-2008 04:08 PM |
| adobe reader installation problem... | vavinashraju | Software Q&A | 5 | 04-08-2007 10:12 AM |
| Facing adobe 8 pro installation problem... | mkmkmk | Software Q&A | 2 | 24-06-2007 10:31 AM |
| Adobe cs3 web premium installation problem! | ╬Switch╬ | Software Q&A | 17 | 27-05-2007 06:22 PM |
| Adobe Photoshop 6 installation problem in winXP | Nimtshey | Software Q&A | 2 | 04-12-2005 12:10 AM |
