Old 17-09-2007, 10:30 PM   #1 (permalink)
Default No way?
Hi Guys,
Windows XP Home Edition. I have got SAMSUNG DVD-ROM. When I put DVD Rom or CD Rom, it takes a very lot of time to open. Any way of opening fastly?
I have got my original version of Windows XP Home Edition. Eager to get the corrupted or missing operating files runing the CD without any damage to my system. Is it possible?
kumarn_2004 is offline
Old 17-09-2007, 11:36 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: No way?
Samsung? Must be dying already
Check if DMA is enabled or not for your drive however, before chucking it out and onto your loud neighbour's head. ( i.e. Only if all CDs/DVDs read slow, don't make a repeat of this )
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-09-2007, 05:05 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: No way?
almost ALL samsung drives have same problem .....
... W H O T ...
ax3 is offline
Old 19-09-2007, 05:31 PM   #4 (permalink)
Call me Sumit
esumitkumar's Avatar
Default Re: No way?
there s a jugaad though
take a pin and insert it into the small hole of DVD ROM which can be seen from front side..it will open
esumitkumar is offline
Old 19-09-2007, 08:43 PM   #5 (permalink)
Exclamation Re: No way?
Hi Guys,
I heard that there is a software for the purpose. But I do not know it.
Old 22-09-2007, 12:45 PM   #6 (permalink)
ax3
ax3's Avatar
Default Re: No way?
@kumarn_2004 .......
check this thread out : CD Drive Tray doesnt come out
hope this helps u .......
... W H O T ...
ax3 is offline
Old 22-09-2007, 12:55 PM   #7 (permalink)
damn busy...
utsav's Avatar
Default Re: No way?
my samsung DVD writer has a problm that when i press the button on the bezel the tray sometimes doesn't comes out but when i eject it through any software it comes out evry time.i guess the front panel button has gone bad and i have to change that button. Should i?
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
