Old 17-09-2007, 08:15 PM   #1 (permalink)
Ankush_is_here's Avatar
Default Xp Hibenate Problem Pls Pls Help
hello guys i have facing one problem pls help me .
i m using xp sp2 when i click on hibernate it will hibernate well but when i turn on my pc it will not resume WELL AFTER SHOWING RESUMING MONITOR DISPLAY DISSAPPEAR i.e there is no display on monitor pls help me what will i do to hibernate my pc.
and turn off and restart were working well.
i have also tried new window but after some time this problem wiill build up in new window too.
`·.¸(¨`·.·´¨)Keep
(¨`·.·´¨)¸.·´ Smiling!
`·.¸.·´ Ankush Gupta
Ankush_is_here is offline
Old 17-09-2007, 08:46 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Xp Hibenate Problem Pls Pls Help
Can you post a list of programs running while you try to hibernate(via Hijackthis log file)
Also try disabling and reenabling hibernation feature.(This will delete your old hiberfil.sys file in C:/.
navjotjsingh is offline
Old 18-09-2007, 01:13 AM   #3 (permalink)
Cool and Calm
abhi_10_20's Avatar
^^^yup and also do yo have a decent amount of RAM ?
When Roger's at play, opponents pray..!!!!!
abhi_10_20 is offline
Old 18-09-2007, 08:53 AM   #4 (permalink)
only firfox and fdm and bluetooth bro
already tried renabling
`·.¸(¨`·.·´¨)Keep
Old 18-09-2007, 11:08 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
May I know ur System config ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-09-2007, 01:32 AM   #6 (permalink)
INTEL 845GVSR ORIGINAL MOTHER BOARD
2.4 PROCESSOR INTEL
256 RAM
80GB HD
`·.¸(¨`·.·´¨)Keep
Old 19-09-2007, 01:47 AM   #7 (permalink)
>:)I-):(|)8-X
Charan's Avatar
I guess its a bluetooth driver problem. Disable the bluetooth service and then try hibernating you system.
Charan is offline
Old 19-09-2007, 02:20 AM   #8 (permalink)
Rebooting
Delete the Hyberfil.sys file...
Go to Control Panel, select Performance and Maintenance, Power Options, Hibernate tab, and uncheck the Enable hibernation box reboot...
Now once again follow that method to enable the Hybernate, now try again...
rebooting
ChotoCheeta.com
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
