Old 17-09-2007, 04:45 PM   #1 (permalink)
Default Settings for?
Hi Guys,
I have got an Mobile and Airtel Internet connection. I would like to do all the settings by myself, like installing PC Suite and making all the settings needed to do Internet. When can I get all the details from?
kumarn_2004 is offline
Old 17-09-2007, 08:44 PM   #2 (permalink)
slugger's Avatar
Default Re: Settings for?
wat have u taken
Airtel broadband or GPRS
slugger is offline
Old 17-09-2007, 09:28 PM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
You need to specify a lot of things dude.
Have you activated any Internet plan on your Airtel mobile services and want to connect to the internet on your phone or want to access the internet on the computer using the phone.
OR
Do you have an Airtel broadband connection on your computer and you want to use it on your phone too?
If it is the 1st case, then it can be done. If it is the 2nd case, it is pretty complex, but possible.
www.twitter.com/alsiladka
alsiladka is offline
Old 17-09-2007, 10:24 PM   #4 (permalink)
OR
Hi Guys,
Activation done.Nokia Mobile.I want to access the internet only on the computer using the Mobile.Having not any Broadband connection. Any more details you need?
Originally Posted by slugger
wat have u taken
Hi Guys,
GPRS
Old 17-09-2007, 10:54 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
So it seems you have activated Airtel Mobile Office.
Now download and install Nokia PC Suite. Connect your phone using USB cable.
Start One Touch Access from PC Suite Launcher.
Click on settings, select your modem and click next. Chose Airtel India from the list of operators.
Click finsh and then click connect. You can then access internet on your computer using the phone as a modem.
Old 18-09-2007, 04:37 PM   #6 (permalink)
Exclamation Re: Settings for?
Hi Guys,
Internet through Mobile is like a Wireless one. Are there much possibilities of getting our e-mails or other things accidently, I mean, by mistake?
Hi Guys,
What about phone number and other settings concerned? Has Airtel India got any website of their own for all details in this regard.What is that?
Old 19-09-2007, 10:44 PM   #7 (permalink)
Originally Posted by kumarn_2004
Hi Guys,
Internet through Mobile is like a Wireless one. Are there much possibilities of getting our e-mails or other things accidently by others without our knowledge, I mean, by mistake?
Hi Guys,
Hi Guys,
Any more suitable replies?
Old 20-09-2007, 12:44 AM   #8 (permalink)
Noobie Pro
alsiladka's Avatar
I am not sure if anybody could sniff the traffic, but its possible i guess.
As to your second query, what is your query man? cant you be specific?
Do you want the settings on your mobile or your PC? For the PC you use the PC Suite, airtel has no info on their website.
Whatelse do you want, you have the settings to connect to the internet on your computer.
For settings on your phone, SMS MO to 501.
Old 20-09-2007, 04:04 PM   #9 (permalink)
[QUOTE=alsiladka]I am not sure if anybody could sniff the traffic, but its possible i guess.
Hi Guys,
Any free software to prevent from doing so?
Old 20-09-2007, 09:53 PM   #10 (permalink)
God of Mistakes...
Garbage's Avatar
hey kumarn, can u please stop your "Hi Guys" ???
I encounter 7 "Hi Guys" in your 5 posts !!
Just kidding !! Take it easy.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
settings for SE P1i rakhunathan Mobiles and Tablets 1 03-09-2007 10:31 AM
Dr. Divx Settings....need help.... Alive_Hunter Software Q&A 2 04-07-2006 01:19 AM
settings are not saved comrade Software Q&A 1 02-03-2006 04:53 AM
C:\Documents and Settings\abc\Local Settings\temp remove it? Huzefa QnA (read only) 6 03-07-2005 10:58 PM
*Help* - Domain Settings cheetah QnA (read only) 3 06-01-2005 10:41 PM
- by Charley
- by tv6952
