Old 17-09-2007, 03:02 PM   #1 (permalink)
Default problem with "my documents"
hi guys
My Document winndow pops up immediately after boot.earlier there were 2 windows popping up but after using the soln posted by Mr Vishal gupta windows decreased to one only.
pls get me a soln to fix it altogether..
mgupta is offline
Old 25-09-2007, 12:19 PM   #2 (permalink)
coolsunny's Avatar
Default Re: problem with "my documents"
i also facing the same problem... needs suggestions guys........
coolsunny is offline
Old 25-09-2007, 01:12 PM   #3 (permalink)
slugger's Avatar
check your startup entry by opening Msconfig
Start->Run->Msconfig.exe
check the Startup tab
delete d one associated with My documents
if u not sure whch 1 cud b d culprit, den list out d startup entries here
slugger is offline
problem in "view" of "folder options" mind021 QnA (read only) 5 23-01-2008 01:43 PM
help!"My Documents"pop up immediately after boot mgupta Software Q&A 1 20-07-2007 12:13 AM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
Redirecting "My Documents" folder karnivore Tutorials 3 01-04-2007 07:04 PM
"Documents" Menu not appearing abhijitroy QnA (read only) 1 15-08-2005 10:32 PM
