Old 16-09-2007, 10:20 PM   #1 (permalink)
LOVING UBUNTU
debaisaindian's Avatar
Default {SOLVED}Plz help recovering hidden folders
hi guys,
I was using a free folder hiding application named FREE HIDE FOLDER......
http://www.cleanersoft.com/hidefolde...ide_folder.htm
Using this application I had hidden some folders in my other drives. Due to a system crash I formatted my system and load the OS again(Windows XP SP2)....now the problem is.......the hidden folders that are located in the other drives are not showing up.......but the drive's free space hasn't increased.......I know the folders are not deleted........n they are there...........
Can anyone knows how to recover it???thn please help.........I had many important data in those folders......
waiting for your quick reply guys........
->Dell Inspiron 1520, Core 2 Duo T7300,2GB SD RAM,8600 256Mb, Ubuntu 7.10 Gutsy Gibbon
debaisaindian is offline
Old 16-09-2007, 11:19 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Plz help recovering hidden folders
Just re-install that Free Hide Folder application and un-hide those folders.
Life is as complicated as you say it is.
shady_inc is offline
Old 17-09-2007, 04:17 PM   #3 (permalink)
LOVING UBUNTU
dude.....thanx for d reply.....but as I have mentioned I have formatted and loaded the OS again.......nywaz got an e-mail of instructions regarding the resetting method from them.......so no need to worry..........
Old 20-09-2007, 11:15 AM   #4 (permalink)
Kiran
Well, don't worry by formatting your hdd you can recover your data if you formatted ur hdd100times by using data recovery software you can get it by searching on google. It has 5mb on size.
Enjoy...
chirkut is offline
not showing hidden folders jayanbhm Software Q&A 25 18-08-2008 05:04 PM
View/Add hidden files/folders in Nero g_goyal2000 Software Q&A 4 25-05-2008 08:27 PM
can't see hidden files or folders!!!!!!!!!!! Yavin Software Q&A 2 17-07-2007 03:39 PM
how to unhide folders hidden by folder guard?? tango_cash Software Q&A 2 20-02-2007 05:33 PM
Where my hidden folders? rambo QnA (read only) 4 01-12-2005 07:59 AM
