Old 16-09-2007, 08:30 PM   #1 (permalink)
in your face..
karnivore's Avatar
Default Query:How to delete all passwords stored on my system
I will be taking my notebook to a service centre for some overhauling. Probably they will re-install my os. However, i want to delete all passwords for my e-mails, forums and other web-sites, all of which are stored on my system.
Can anybody tell me how to do that.
PS: Using XP Pro, SP 2.
karnivore is offline
Old 16-09-2007, 10:37 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Query:How to delete all passwords stored on my system
Clear private data in browsers, back up mail accounts and delete them.
Doesn't this seem a pretty simple job?
You can use tools such as Foxie to clean multiple browsers simultaneously.
Edit: Heck, just delete your User ID! All will go BOOM
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-09-2007, 10:42 PM   #3 (permalink)
Google Bot
Pathik's Avatar
U can also try ccleaner.. Or manually delete all ur browser data
Pathik is offline
Old 16-09-2007, 11:20 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
One may Do it manually too...
if you have IE 7, then, Go to Internet options, by Clikcing Tools under IE 7, then Internet Options...
Now Click Delete on Browser History...
Now in the next pop up Window, Click Delete Password if you want to Delete all Saved Passwords,
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 16-09-2007, 11:22 PM   #5 (permalink)
in your face..
karnivore's Avatar
^^ thx. now i really feel stupid.
Sorry for the silly querry.
delete icons from task bar/ system trey mohitgiri Software Q&A 6 30-03-2007 09:56 PM
System temparature Query ??? vijay_7287 QnA (read only) 3 03-11-2005 05:59 PM
HOW TO DELETE THE STORED USERNAMES IN IE aman_agrawal QnA (read only) 2 30-05-2005 08:53 AM
Comment on my new system(plus query) HellGuardian QnA (read only) 4 17-02-2005 12:14 AM
where windows XP updates are stored in my system Choto Cheeta Software Q&A 4 12-12-2004 04:07 AM
