Old 16-09-2007, 06:20 PM   #1 (permalink)
sourav's Avatar
Default Help! Slow Shutdown
Today I saw my computer taking a lot of time to get shutted down.before it was taking 2-3 minuter, but now it must above 6-8 minutes.
i don't know why it is happening.
to check it i installed and ran ccleaner and also spybot updated till september one given in digit.
i really need help as it is taking a lot of time
please don't suggest to reinstall windows xp.
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 16-09-2007, 06:26 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: Help! Slow Shutdown
6-8 minutes man thats a lota time.
If you are using a pirat*d version then its a common problem.
And anyways everybody knows windows keeps on slowing down with time so no rael solution.But you should try defragmenting your HD and do a full system virus scan.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-09-2007, 06:36 PM   #3 (permalink)
sourav's Avatar
The problem started today only.
today at the morning it was working fine
but watching the cricket match it started showing that problem.
windows is not all slow, it is just the shutdown time, and yes all that time it does show hd activity, that means some memory access is there and a vigorous one. so help
i am going defragment my hd now, let see what happens
sourav is offline
Old 17-09-2007, 12:02 AM   #4 (permalink)
what do you think is the reason that is so?
realdan is offline
Old 17-09-2007, 11:55 AM   #5 (permalink)
Pee into the Wind...
shady_inc's Avatar
http://www.aumha.org/win5/a/shtdwnxp.htm
The link probably lists most of the factors that can lead to slow shutdown.
Even 2-3 minutes is a lot of time for shutdown.How much RAM have you got??
Life is as complicated as you say it is.
shady_inc is offline
Old 17-09-2007, 12:29 PM   #6 (permalink)
Kiran.dks's Avatar
Things to check:
1. Check the disk space in Windows Partition.
2. See the start-up entries for any newly added unusual entry.
3. Make sure that Windows is up-to-date. (Windows Automatic updates)
4. Perform a full scan using a good antivirus software and antispyware software in "safe mode".
If problem persists, please post HijackThis log report here for analysis.
Kiran Kumar R
Kiran.dks is offline
Old 17-09-2007, 12:52 PM   #7 (permalink)
Multicore Mutant
Solution is to Install a Microsoft component "User Profile Hive Cleanup" also know as UPHClean
Get it from here: http://www.softpedia.com/get/Securit...-Service.shtml
Hackattack is offline
Old 17-09-2007, 03:07 PM   #8 (permalink)
sourav's Avatar
1 gb but ddr 333
sourav is offline
Old 17-09-2007, 03:41 PM   #9 (permalink)
Multicore Mutant
Have you tried my solution ??
Old 17-09-2007, 03:45 PM   #10 (permalink)
sourav's Avatar
now i am trying kiran's solution but i have downloaded ur one.
re-installing all drivers
wait, this has started this sunday
so should i start system restore, i am going to do that
sourav is offline
Old 17-09-2007, 04:15 PM   #11 (permalink)
Multicore Mutant
I was facing similar problems few months back, tried lot of things like CCleaner, Maxregistry cleaner, scanned the system with different spywares, done hijack this, but none worked. Then i googled and found many facing similar problem, UPHclean seemed to solve the slow shutdown problem.
Earlier my system took around 1min to 1.5min to shutdown, but after i installed the UPHclean it solved my problem, now my system shuts down in less than 5 sec.
Old 17-09-2007, 04:49 PM   #12 (permalink)
sourav's Avatar
now i am felling like it is a software problem
my computer is not going to previous state
ok i found threatfire is the culprit
sourav is offline
Old 17-09-2007, 05:00 PM   #13 (permalink)
Multicore Mutant
Xp shutdown very slow webgenius Software Q&A 8 06-02-2007 10:43 PM
booting and shutdown very slow.......help plzz anilthomas26 Software Q&A 33 22-05-2006 01:12 PM
slow 'horse' after an improper shutdown . hellomotto Hardware Q&A 3 27-03-2006 09:26 AM
Virus, Shutdown slow r_jayesh Software Q&A 4 06-07-2005 08:00 PM
slow shutdown in xp with service pack 2 naveen_reloaded Software Q&A 7 25-05-2005 10:12 AM
