Old 16-09-2007, 12:59 AM   #1 (permalink)
lalam's Avatar
Default What is this error? Help!
Well it all started out with me happening to download a virus unknown to me. Already did all the virus scanning and now my pc is as good as it was except for this problem that comes up whenever i click on the drive icon on my computer. Please check the attachment and help! Thanks in advance.
lalam is offline
Old 16-09-2007, 01:07 AM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: What is this error? Help!
there will be autorun.inf file in ur drive delete the file, located in the root of the drive
My Stomach pains
http://tinyurl.com/32jj4m
zyberboy is offline
Old 16-09-2007, 01:09 AM   #3 (permalink)
lalam's Avatar
Where do i find that?
Tried searching and it throws up about 5 autorun.inf files all associated with some programs.
lalam is offline
Old 16-09-2007, 01:10 AM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
open the drive,show hidden file shud be enabled...u r talking abt hdd drive isn't?
autorun.inf is a hidden file
edit: and also u may need to restart da compu after deleting the file in order to changes to take effect
My Stomach pains
zyberboy is offline
Old 16-09-2007, 01:17 AM   #5 (permalink)
lalam's Avatar
Yep its the hdd drive. Found one with autopatcher deleted it yet no use?
I have five partitions and its happening on every partition though it works fine if i right click on it and click on open and explore. Just that its not accesible anymore if i double click on it.
lalam is offline
Old 16-09-2007, 01:19 AM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
have u restarted the compu??....chk if the file is re-appearing if yes then virus is in memory u will need to clean it with other av
My Stomach pains
zyberboy is offline
Old 16-09-2007, 01:21 AM   #7 (permalink)
lalam's Avatar
Did restart the computer and that error still shows. Also already scanned it with kaspersky so what do i scan it with now?
lalam is offline
Old 16-09-2007, 01:25 AM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
is the file reappearing in the drive??
edit: Try this
http://www.techiecorner.com/122/how-...ms32dlldllvbs/
My Stomach pains
zyberboy is offline
Old 16-09-2007, 01:35 AM   #9 (permalink)
lalam's Avatar
No it doesn't i mean the auto patcher one. Haven't found another autorun.inf file on c:
edit: Try this
OMG!!!! That freaking msg appears everywhere with IE! I guess those tips given there would help i hope.
THANKS A LOT cyberboy Done away with the problem now
lalam is offline
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
error while trying to retrive text for error ORA-12203 vikasg03 Software Q&A 1 14-11-2005 02:48 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
