Old 15-09-2007, 01:38 PM   #1 (permalink)
Default Dedian Linux problems
Hi all,
my pc configuration is
Intel D965RY MotherBoard
Intel P-D 3.2
1 GB RAM
DVD writer LiteOn
But when i try to install debian 64 bit, the system is boot but can't mount the cd rom or dvd rom drive.
i change my dvd writer with old cd rom but same error i face.
any solution ...
thanks
Ashutosh Malik is offline
Old 15-09-2007, 01:44 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Dedian Linux problems
You didn't specify
1. Debian Version
2. System config type : 32 or 64 bit
3. What error u faced!
I suggest u take on July Digit issue which gives Fedora 7 or latest Ubuntu distroo and then try!
mediator is offline
Old 15-09-2007, 01:46 PM   #3 (permalink)
left this forum longback
praka123's Avatar
First of all not dedian,it is Debian GNU/Linux http://debian.org
Debian Etch will not support jmicron ide pata controller in 965 boards so will not work.but u can try debian lenny/sid.latest kernel
consider Ubuntu Feisty 2oo
praka123 is offline
Old 15-09-2007, 04:22 PM   #4 (permalink)
Hi all,
My Debian is 64-bit . Version is 4.5.
Old 15-09-2007, 04:23 PM   #5 (permalink)
praka123's Avatar
kernel version?
praka123 is offline
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
Linux CD problems Goldi Open Source 6 10-07-2006 03:04 AM
Linux CD problems Goldi Open Source 2 12-04-2006 08:10 AM
HDD to HDC = problems for linux ??? klinux Open Source 4 28-11-2004 03:08 PM
