Old 15-09-2007, 10:03 PM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Not able 2 write dvds :( -Vista64U HP lappy
noticed recently.. on my 2GB ram C2D Vista 64bit ultimate lappy... i am not able to write dvds... using any software...
i was able to do it earlier... but now... not able to.
when i did the vista default burning.. it did to a point and stopped... but the dvd showed as empty.. it kept repeating the prob...
I noticed the prob when i infrarecorded... though its not the prob of that sw... as it was not writin even after reinstallation... capture below...
Another info needed... what is the purpose of Upper/Lower Filters in CD/DVD readers/writers? Anythin with it.. can any1 throw light on it....
any1 listenin?
koolbluez is offline
Old 16-09-2007, 10:40 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Not able 2 write dvds :( -Vista64U HP lappy
Media incompatibility? Are you trying a new media and that is which is not burning?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-09-2007, 10:47 PM   #3 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
it was writin in earlier... dunno y not now
tnx.... for replyin...
Old 16-09-2007, 10:50 PM   #4 (permalink)
Commander in Chief
Try some established burning software like Nero? Your problem appears to be very odd, but assuming its a new laptop drive, I hope your drive is still well physically.
Harsh J
www.harshj.com
Old 16-09-2007, 10:53 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Not much idea abt the prob but is it the case wit vista only or all oses?? Btw y do u always keep writing zanjeer.divx?
Pathik is offline
Old 16-09-2007, 10:53 PM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
tried nero first
very queer prob... so asked here... if some1 else faced a similar prob?
no idea of other os... pats... same pic u saw somewhere else here... so u saw the same name.... help me out here.. dude...
Old 16-09-2007, 11:24 PM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
notice an I/O error? i hope you didn't give any jerks to the lappy while it was burning... since its giving errors in all software it most prolly not a software problem. try removing the drive and the controller to which it is attached in the device manager and let windows install the drivers again. see if this solves the problem. otherwise take it to the service center if still under warranty or open up the laptop if its not and try to reconnect the drive.
infra_red_dude is offline
I cannot write DVDs.. shyamno Hardware Q&A 11 07-02-2007 08:04 PM
unable 2 write DVDs slugger Hardware Q&A 8 17-01-2007 07:51 PM
Repair dvds with write error, make them resusable? yash QnA (read only) 4 10-12-2006 08:11 PM
