Old 14-09-2007, 08:44 PM   #1 (permalink)
Default Problem With My Videos
Dear Friends,
Im having problem with My videos, unable to open it, delete it, move it, rename it, and it was having some stuff but now it shows empty...
The error message is Access Denied...
Im Attaching the photo for the same kindly have a look and solve it...
Thank u all.
xlnt123 is offline
Old 14-09-2007, 08:46 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Problem With My Videos
Do u mean the My Videos Folder?
If it says access denied... then in case if u r not the admin of the system... ur admin might have set those permissions.
Gigacore is offline
Old 14-09-2007, 08:49 PM   #3 (permalink)
It is in my laptop and Im the admin
xlnt123 is offline
Old 14-09-2007, 08:52 PM   #4 (permalink)
slugger's Avatar
i suggest u run a scan with a good AV like KAV or NOD32
probably been hit by a virus/worm or sumthin
problem with similar symptoms have been reported by other members 2, but with slight variation tho
slugger is offline
Old 14-09-2007, 08:56 PM   #5 (permalink)
I have AVG always on in the memory and no other corruption till yet so many days
xlnt123 is offline
Old 14-09-2007, 08:58 PM   #6 (permalink)
slugger's Avatar
is it only dat 1 folder where u face this problem or are there sum other folders also
also are u able to open d Registry & Folder option window?
slugger is offline
Old 14-09-2007, 08:59 PM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
Try System Restore.... to the days u remember, where it was working
Gigacore is offline
Old 14-09-2007, 10:02 PM   #8 (permalink)
It is only one folder and I can open other folders as well as the registry & folder option window...
Restoring may not be possible.....
xlnt123 is offline
Old 14-09-2007, 10:19 PM   #9 (permalink)
Dreamweaver
Gigacore's Avatar
Do u know the cause for this prob... i mean after installing any apps..
Gigacore is offline
Old 15-09-2007, 07:21 PM   #10 (permalink)
It is after I formatted my C: partition and I've not touched D: (data Partition) but then again I set My documents to D: (As it was previous before Formatting C
Now I want to delete this folder I don't think I can get my data back but I want to delete it so that I can make a new folder named My videos......
Any Advice???
Thank U alll
xlnt123 is offline
Old 15-09-2007, 07:38 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
It's been Encrypted I guess. Use those guides to get the ownership back and see if it works?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-09-2007, 08:34 PM   #12 (permalink)
How???? Which Guides???? Pls Help....
xlnt123 is offline
Old 18-09-2007, 10:27 PM   #13 (permalink)
No Help Why???? Is it such a Peculiar Prob that no one is helping....
xlnt123 is offline
Old 19-09-2007, 03:14 AM   #14 (permalink)
try any file washer tool
like bcwipe
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is online now
Old 20-09-2007, 12:31 PM   #15 (permalink)
Thanks Downloaded will try and reply....
xlnt123 is offline
Old 21-09-2007, 08:22 PM   #16 (permalink)
Doesn't work.......
Does No one has the solution.....??????????? Mods (Senior Members) please Help....
xlnt123 is offline
Old 21-09-2007, 08:45 PM   #17 (permalink)
then only solution left is to format the drive.
just backup ur data.
Faun is online now
Problem while downloading youtube videos ratedrsuperstar Software Q&A 11 24-03-2008 02:09 PM
DRM Videos chicha Software Q&A 2 13-08-2007 09:00 AM
i-pod videos related problem-plz help ! lovemeall26 Software Q&A 4 11-10-2006 04:29 PM
Problem Playing AVI format videos on 6600 amol48 Buying Advice 7 21-01-2006 10:36 AM
Problem encoding videos to DivX bizzare_blue Software Q&A 4 11-01-2006 11:09 AM
