| Forum |
#1 (permalink) |
#3 (permalink) |
Pee into the Wind...
Did u restart ur PC after uninstalling Avast??Two anti-viruses running in same PC give you a extremely slow PC at best.
Life is as complicated as you say it is. |
#4 (permalink) |
Distinguished Member
i have not seen yr images. so speaking generally.
uninstall avast in safe mode if u have a problem / use McAfee Uninstall Tool to uninstall McAfee completely. get it from mcafee site. after both have been uninstlld, use reg cleaner like ccleaner. then try to instl what u want to install.
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
#5 (permalink) |
yeah i reboot my PC after uninstallation of avast. But same problem still persists.
i used ccleaner to clean my registry. but i'm still not able to install it. Last edited by The Nilay; 14-09-2007 at 10:10 PM. Reason: Automerged Doublepost |
#6 (permalink) |
Wire muncher!
as anand said, it most likely looks like a bad uninstall of either of the two AVs. download the mcafee uninstaller and then try again. also goto the registry editor and delete any reference to mcafee and/or avast before installing again.
oftopic: just 1 dialog box in the bmp file.... takes up 1.4mb and when compressed in .zip format becomes 9.2kb!! edit: oh saw ur edited post now. so i think something is remanant from the prev. install. u need to hunt it down. i'd seriously suggest kaspersky or nod32 (both paid) or even AVG (its free). all are much much much better than mcafee!
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#7 (permalink) |
D i s t i n c t l y Ahead
i had also suffered with similar problem solved it by running registry cleaner
Use Ccleaner for this purpose also even after Mcafee UnInstalls Some file of it runs in background so fire up Task manager nd Disable some process like Msshild (some thing like this ) and then delete its folder from Program files then try to install Off topic :i will suggest u to through such a crap anti virus nd try Kaspersky |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| wikipedia installation problems | utsav | QnA (read only) | 1 | 07-08-2007 12:04 AM |
| mandriva installation problems | azzu | Open Source | 4 | 19-05-2007 08:53 PM |
| Maya 8.0 installation problems :( | deepak.krishnan | Software Q&A | 8 | 23-04-2007 02:40 PM |
| Ubuntu Installation Problems | adit_sen | Open Source | 13 | 10-08-2006 11:52 PM |
| Problems during PCQ installation. | IG | Open Source | 7 | 23-12-2004 11:43 AM |
