Old 14-09-2007, 03:34 PM   #1 (permalink)
Beware of the innocent
ilugd's Avatar
Default Disk Drive Partition E: says access denied on double click but explores
Hi, I am facing a peculiar problem. I have 2 partitions on my sata hard drive. I boot off the first into windows and have the second to store all my files and profiles. My mydocs is mapped to the second drive (e. However when I doubleclick on the drive in explorer, I get an access denied error. Right clicking and clicking open does the same. Right clicking and exploring works. But when I open explorer with winkey+e and double click, it is supposed to explore by default but rather tries open and fails. I then have to right click and explore.
The drive works fine otherwise but I am sick of this. Since my mydocs is mapped to the drive, whenever i try to save a new file, i get a bunch of errors if the software tries to show the save dialog for that drive.
I tried googling but couldn't find any coherent solution. Any ideas?
Life is too short. Have fun.
ilugd is offline
Old 15-09-2007, 10:41 AM   #2 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Disk Drive Partition E: says access denied on double click but explores
Explore that drive and check if it has any autorun.ini file. If there is delete it now you should be able to explore it and also check your system for virus.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 15-09-2007, 11:22 AM   #3 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
my friend has the same problem ... must be some virus but cant detect ... some vbs file gets created when trying to open drives ..and have to explore it.. is there some way to stop this problem ....
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 15-09-2007, 11:28 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
Me to suspect a virus... if not registry is screw its better 1st see and hunt down if any virus.... then thinking of Going to Registry or Advance settings..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-09-2007, 03:28 PM   #5 (permalink)
These are usb viruses which are auto copied when u connect to a system
Go to tools>folder options>view>
enable show hidden files & folder
uncheck hide protected OS files
Now search all root drives including ur usb drive which infected the comp & delete all "auto inf" files from it........................that should get you rid of this virus.
If you disable autoplay for all kinds of drives then u wont get infected with such virus.
ranjan2001 is offline
Old 15-09-2007, 10:09 PM   #6 (permalink)
ilugd's Avatar
thanks. I will try it out on monday.
ilugd is offline
Old 16-09-2007, 12:08 AM   #7 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
This is a very common virus.Just delete the autorun.ini file and autorun.exe(if present) files.
Better search net to find some removal utility for complete removal of this virus.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-09-2007, 10:41 AM   #8 (permalink)
Its Best only if its open
ankushkool's Avatar
how 2 disable auto play 4m all drives????
ankushkool is offline
Old 16-09-2007, 10:51 AM   #9 (permalink)
This should help, many 3rd part software also have options to do so.
http://www.howtogeek.com/howto/windo...nd-usb-drives/
Old 17-09-2007, 01:25 PM   #10 (permalink)
ilugd's Avatar
nope.. no autorun.inf files. No virus.
ilugd is offline
Old 17-09-2007, 01:32 PM   #11 (permalink)
Try http://www.dougknox.com/xp/fileassoc...iation_fix.zip
Arun
sakumar79 is online now
Old 17-09-2007, 01:32 PM   #12 (permalink)
Kiran.dks's Avatar
I assume that you are using Windows XP Pro.
This may be something to do with "Permissions".
Please go to security tab of the drive (right-click context menu) and reset/take ownership again.
Kiran Kumar R
Kiran.dks is offline
Old 17-09-2007, 02:33 PM   #13 (permalink)
ilugd's Avatar
^^^ and the one above. tried both. No luck.
ilugd is offline
Old 17-09-2007, 04:46 PM   #14 (permalink)
Multicore Mutant
Those autorun.ini and VBS files are hidden, check after unhiding files and folders, also uncheck the "hide protected operating sytem files".
Hackattack is offline
Old 17-09-2007, 04:52 PM   #15 (permalink)
Thats what I mentioned in this post
Old 17-09-2007, 05:10 PM   #16 (permalink)
ilugd's Avatar
uh... well unhid the system files. There is just a desktop.ini. No problems in that. Opened with notepad.
I just noticed something. When I right click, I get the 'Open (O)' as the default option. But open and explore are both there below that. I guess it is a hijack. Will post the hijackthis log.
ilugd is offline
Old 17-09-2007, 05:16 PM   #17 (permalink)
Multicore Mutant
Aaha thats the proof that your system is infected m8 with some MS32.vbs.dll, nod32 will clean it out.
Old 17-09-2007, 05:16 PM   #18 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Cant Access My drive
see if this thread helps
wizrulz is offline
Old 17-09-2007, 05:22 PM   #19 (permalink)
ilugd's Avatar
i have a copy of the great etrust antivirus on my system. I am supposed to recommend that antivirus to all users since we have corporate license. What the hell was it doing? sleeping?
Damn autorun.inf found on pendrive. Code here
[AutoRun]
Shell=Open(&O)
shell\Open(&O)\command=RECYCLED\appmgmt.exe
ilugd is offline
Old 17-09-2007, 05:40 PM   #20 (permalink)
hi...if possible update nod32 and run a full system scan..nod32 is the best ot thre and u may get ur prob solved
ena...enakku problem solve aidchu
Naren Parker is offline
Old 17-09-2007, 07:52 PM   #21 (permalink)
No anti virus can stop this bcoz usb autorun is a considered normal operation, good that u now have found the virus.
Old 17-09-2007, 07:54 PM   #22 (permalink)
ilugd's Avatar
i don't do nod man. I do etrust. I hate my ho admins who make me do that.
ilugd is offline
Cant open drive with double click naveen_reloaded QnA (read only) 6 17-07-2007 08:48 AM
Can't Open any of my hard drive with double click jimmyondigit QnA (read only) 10 11-02-2007 05:09 PM
access denied in opening my c drive... ravidawar Software Q&A 6 03-02-2007 05:40 PM
USB Drive - "Access Denied" in Explorer, but works through autorun. navraj Hardware Q&A 3 29-01-2007 05:08 PM
- by Niilesh
