I have two HDD's with two partitions on each. Yesterday I re-installed Windows XP on the first HDD and to my horror XP detected only the first partition on second hdd...this 'lost' partition is NTFS and has about 30 GB of crucial data. In Disk Management too, it shows only the first partition on second HDD...I have tried follwoing tools with no help:
1.Stellar Phoenix Windows Data Recovery v3.0- Successfully detects the second logical partition on second HDD with all the files and folders, but when I try to save them to other location, it wont allow me to coz its a demo version! duh. And no, so far I havent been able to "procure" serial for that.
2. Smart Data Recovery and Smart NTFS Recovey- both these tools DO NOT
show the "invisible/lost" partition at the starting prompt and so I cannot proceed as it requires you to first select the partition to find the lost data on.
3. PC Inspector File Recovery- Inconsistent Behaviour. Shows contents of only SOME folders, which I CAN recover, but doesnt at all show for ALL folders.
Then, I tried Linux Live! CD's...LinSpire and Ubuntu, to be specific. Both these OS'es DO show my partition, but I am unable to copy data to first HDD. It gives me "not sufficient permission" error. Will INSTALLING Linux allow me to create a new folder and copy data onto it??? Right now it doesnt even allow me to create a new folder. Is burning DVD easy on Ubuntu? I am totally n00b in Linux, obviously.
Can PLEASE anyone suggest me a solution (preferably in Windows) to recover this "invisible/lost" partition fully?? I would be really greatful.
Thanks in advance.
