Old 10-09-2007, 07:19 PM   #1 (permalink)
msnways1's Avatar
Question WinRAR file extraction problem...
I'm really need help over exctracting movie from rar. I got 6 files with split volumes. But I can't find last 7th file to extract 1 movie file. Hence winrar gives error on extraction - volume file missing.
But I want to extract movie file from these 6 split volumes, thinking that atleast 80% movie is present in available volumes.
Please help me to extract movie file from split volumes.
Thanks...
msnways1 is offline
Old 10-09-2007, 07:36 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: WinRAR file extraction problem...
I guess you can perform partial extraction using the -kb parameter of the winrar.exe
P.s. Am not sure of it, just heard it somewhere. And the -kb would be "Keep Broken Files" if you're using the GUI. It must be there somewhere in extraction options.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-09-2007, 07:47 PM   #3 (permalink)
msnways1's Avatar
Thumbs up Re: WinRAR file extraction problem...
Yeah, its working dude. thanks a lot. i just reqd to use unrar.exe with command prompt. thanks a lot!!!!!
msnways1 is offline
Old 10-09-2007, 08:24 PM   #4 (permalink)
Commander in Chief
No problem Am sorry I mentioned winrar.exe, it should have been unrar.exe as it is unrar on Linux but I wasn't sure of it ..
Harsh J
www.harshj.com
Old 01-10-2007, 12:20 PM   #5 (permalink)
But mine prob with password...... i forgot it can its possible to break it without password......?
qadirahmed is offline
Help : Forgot Winrar file pwd esumitkumar Software Q&A 1 09-07-2007 05:58 PM
winrar problem!!! prinz Software Q&A 6 07-06-2007 10:47 PM
help needed on WinRAR problem!!! prinz Software Q&A 8 04-06-2007 09:44 AM
Winrar Problem Goldi Software Q&A 2 01-06-2006 08:10 PM
- by Niilesh
