Old 10-09-2007, 04:07 PM   #1 (permalink)
Default connect a microcontroller
can anyone tell me how to connect a microcontroller and also where
Bigtech is offline
Old 10-09-2007, 04:11 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: connect a microcontroller
Connect what? .. which microcontroller are you using ?
Charan is offline
Old 10-09-2007, 04:15 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
hehehe ... where do u want to connect the micro controller ... if u want to connect it to the pc there are kits that u connect to the com port of ur pc and place the controller n it for programming
http://beingmanan.com
iMav is offline
Old 10-09-2007, 05:03 PM   #4 (permalink)
Ganeshkumar's Avatar
I think u r confused.... first gooogle wat is Microcontroller!
Ganeshkumar is offline
Can I connect 2 internet connections Connect at a time? gaju6696 Internet & WWW 6 06-02-2009 08:26 PM
help me connect to Net!!! dreamzchm Software Q&A 2 27-06-2007 01:05 AM
Can't Connect!!! phanibhushan Software Q&A 6 16-02-2007 11:01 PM
Connect me to net kapsp5001 Mobiles and Tablets 2 13-02-2007 11:49 AM
8051 Microcontroller and SDCC - Gnu GPL C Compiler sci-3d Open Source 1 27-08-2006 06:16 PM
