Originally Posted by ax3
yes u can use ur external hdd .............
How to install virtual drive on External hdd, i cant find that option.
Originally Posted by navjotjsingh
You should use Image Making Wizard. Copy Wizard is best for copying CDs to CDs or DVDs to DVDs.
What do you mean by using on external disk? Please elaborate.
I have 2.5 Hard disk connected via USB . I want to use external hard disk for virtual drive.
Why are you then creating mds images? Try creating ISO images. Then check the size. Also try this
Select Datatype as Normal DVD. Also uncheck Read Sub Channel Data from current disc. And try checking Fast Skip Error blocks and Skip Reading Erros.
And then check what size mdf gets created. MDF images are a bit larger than normal though. You can try ISO or any other image format.
There is no option for Select Datatype as Normal DVD
There is option for Select Datatype as Normal CD
also some DVD i can create 2 gb mds file but some DVDs i have only 1.30 GB and the file coming to 4.28 GB , Why
