Old 09-09-2007, 04:18 PM   #1 (permalink)
Exclamation plz help me about these viruses
hi plz guide me how can i remove these viruses
1. copy.exe,host.exe,autoplay.exe
2.services.exe removal tool
plz give me ultimate result
Ravi.Y
yrakesh78 is offline
Old 10-09-2007, 03:22 PM   #2 (permalink)
I'm back!
Default Re: plz help me about these viruses
Well the strategy you employ to fight off a virus depends on the type of infection itself. It's a tedious process and explaining it in a post is even more tedious and probably that's why none have replied to you!
But here's what you can do that probably should work. It actually does for minor infections!
Download an anti-spyware like Ad-Aware, Windows Defender or Ewido etc. Install it and boot your PC in safe mode. Run the anti-spyware you installed and do a thorough scan. This should remove the infection! If the anti-spywares are unable to remove the infection try free anti-viruses like AVG, Avast! etc.
If the virus doesn't let you install the anti-spyware properly try online scan services like TrendMicro's HouseCall, Ewido's OnlineScan or Panda's ActiveScan etc. Online Scanners will require you to install their plugin/activex control and would normally run on IE only.
Hope this helps!
Little Knowledge is Dangerous but a lot of Ignorance is just as Bad!
Minimalistix is offline
Old 10-09-2007, 03:48 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
download install update avast antivirus and avg antispyware.
scan with both of them in safe mode.
run ccleaner
all freeware
google for their links.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-09-2007, 05:33 PM   #4 (permalink)
Nav11aug's Avatar
better still .. schedule a boot-time scan wid Avast instead of SafeMode
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Want some great viruses max_demon Software Q&A 8 28-12-2006 06:59 PM
how to beat viruses Ramakrishnan Tutorials 6 30-07-2006 02:50 AM
Is there any way to remove these viruses. H.Lalnunmawia Software Q&A 3 20-03-2006 06:05 PM
Help removing Viruses sakumar79 Software Q&A 8 12-07-2005 02:33 PM
No Viruses in Linux???? suj_engico Open Source 18 12-03-2005 03:26 PM
