Old 07-09-2007, 05:44 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Strange problem with Internet in Win XP???
Hello guys!
I have a rather strange problem. I have a P4 2.8 Ghz. on a Intel 865GBF motherboard with 512 MB DDR RAM. I did a fresh installation of Win XP SP2, disabled Windows Firewall and installed Kaspersky AntiVirus. Now when I connect to my BSNL Broadband connection (via LAN through ADSL Modem), it connects smoothly and internet seems to work quite smoothly for a few minutes and then the problem starts. Just after a few minutes, all internet data flow stops although I still have the connection symbol in my task bar. When I doubleclick on the network icon on the task bar, nothing opens and even if I disconnect by right clicking on the icon, I am not disconnected. Even after I switch off my ADSL modem, I still see the connection icon intact. Now, till the time I dont restart my computer, I am not able to connect again. After reconnection, the same problem starts in a few minutes. The funniest part is that if I enable the Firewall, everything starts working smoothly. Does this mean that I cannot work on the net without enabling the firewall.
Can you please help me in solving this problem...
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 07-09-2007, 05:46 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Strange problem with Internet in Win XP???
if possible when you connect to the Net, run a ping to yahoo.com or google.com constant, and refer there if youi see no data Transfer, do post the screen shot of the ping result..
Command, ping yahoo.com -t
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-09-2007, 09:28 PM   #3 (permalink)
same problem here cant disconnect or disable local arena network (juz formated my pc yesterday and havent installed anything)
Ravirdv is offline
Old 07-09-2007, 11:21 PM   #4 (permalink)
slugger's Avatar
how did u disable d Firewall- from d control panel Firewall short cut or did u disable d service
if u have done d first den try disabling d service after that
(not sure if it is d right suggestion, but since u mentioned firewall is not needed den might as well disable it completely and c if it solves ur problem)
slugger is offline
Old 07-09-2007, 11:51 PM   #5 (permalink)
left this forum longback
praka123's Avatar
stop the reg services via "services.msc"
praka123 is offline
Strange problem with Internet Speed alanpaladka Internet & WWW 9 10-03-2007 04:29 PM
a strange problem rajdeepsingh86 QnA (read only) 5 04-01-2007 01:19 PM
strange problem harshagarwal QnA (read only) 10 22-06-2005 05:21 PM
Strange Modem/Internet Problem mohit Networking 4 20-04-2005 10:43 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
