Old 05-09-2007, 08:32 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default Problem With system date !!!
Today evening when I switch on my system during booting it shows "CMOS check sum errors", I press F1 to continue, and the computer starts fine.After a few second a msg pop-up says kaspersky antivirus trial period over, purchase licence key. Immediately I cant understand how it is possible because I installed KAV on 31/08/07, than I understand that my system date is wrong. I rectified the date, but KAV not rectified, it is still showing out of date. Then I uninstall KAV, and reinstall it, but the problem is not solved. Is there any way to reactivate KAV for the balance period of 24 days.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 05-09-2007, 08:45 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: Problem With system date !!!
dude i think you are using a pirated software, stop buy it it costs only 1200 rs
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 05-09-2007, 08:54 PM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
No dude I have downloaded it from official Site of KAV 30 days trial package.
You can check it here
Old 05-09-2007, 09:18 PM   #4 (permalink)
in search of myself
CadCrazy's Avatar
Replace your CMOS battery on your motherboard
Here is the Procedure
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 05-09-2007, 09:25 PM   #5 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
I have already changed the battery and rectified the date. But KAV is still out of date.
Old 05-09-2007, 09:43 PM   #6 (permalink)
in search of myself
CadCrazy's Avatar
then its a strange prob.
Unban Praka123
CadCrazy is offline
Old 05-09-2007, 09:47 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: Problem With system date !!!
just reinstall kav ur problem will be solved
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 05-09-2007, 09:51 PM   #8 (permalink)
slugger's Avatar
i dont think chaging d battery or re-installin it will hellp
C
wen u got d first CMOS error, d BIOS d8 was changed to its factory deafult
and u still went ahed and booted meaning KAV was also loaded, wen KAV checks d existing system d8 wit d d8 wen it was installed, it thinks dat u r trying sumthin fishy with d sw (and sine u from Assam it nkow u have access to lots of fishes )
KAV has already made a registry entry regarding d d8 confusion and will now assume u r tryin to use KAV beyond d 30 day period
now ur options
1. Find dat entry and delete/modify it (ROFL)
2. Format HDD re-install OS+KAV (recommended)
slugger is offline
Old 05-09-2007, 09:53 PM   #9 (permalink)
Pee into the Wind...
shady_inc's Avatar
Anyone here could have worked that out,strangely enough....
CMOS checksum error is usually a sign of dying battery.So better get a new battery.For the KAV issue you can try emailing those guys.They will be able to help u best,I think.
Life is as complicated as you say it is.
shady_inc is offline
Old 05-09-2007, 09:55 PM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
Please try this:
1. Download KisKav6Remove.zip & .Regsupreme (install this one) and a new installer http://www.kaspersky.com/productupda...pter=186437046.
2. Make a folder called Kav 6.0 on the desktop and unzip KisKavRemove into this,, then uninstall Kaspersky, reboot into safemode and run the tool (doubleclick on "avp_remove.cmd" for the 6.0 tool). Only works if installed in the default c:\ location with windows!.
Now i would run the trial of Regsupreme, run it (use normalmode only, not aggressive), when finished scanning you rightclick and select "All", then you click "Fix" at the bottom, it will ask you if you wish to make a backup and you do, just to be safe.
3. Now boot into normalmode and install Kaspersky again.
from kaspersky forums.
http://downloads1.kaspersky-labs.com...Kav6Remove.zip
http://www.macecraft.com/regsupreme/
infra_red_dude is offline
Old 05-09-2007, 10:19 PM   #11 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Problem With system date !!!
download your uninstaller or total uninstaller.
and reinstall KAV thru this softwares, it will show all the registry changes done before & after installing KAV, so now u can easily identity which all registry entries to remove after uninstalling KAV.
actually this is availabie in either of one software, check both of them.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 05-09-2007, 10:29 PM   #12 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
I think u are right. How I have to find dat entry and the No2 option is not possible.
Originally Posted by infra_red_dude
I am finding your process is cumbersum. At last I will try it. thanks for suggestion
I think Your guidence will work. let me try.
Old 05-09-2007, 10:30 PM   #13 (permalink)
Wire muncher!
^^^ that process is cumbersome that formatting and reinstalling everything again????
Old 05-09-2007, 10:31 PM   #14 (permalink)
in search of myself
CadCrazy's Avatar
Mujhe isme se piracy ki badboo aa rahi hai. M i right
Unban Praka123
CadCrazy is offline
Old 05-09-2007, 10:39 PM   #15 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
If it is not solved I dont format the hdd, instead I will install again Avast or AVG. Avast which one is I am using for last 4 yrs.
Old 05-09-2007, 11:24 PM   #16 (permalink)
slugger's Avatar
not really
if u mess with d system d8 after a 30-day trial sw is installed, den it is quite natural 4 d sw to stop working
bcos d sw is expected to work on thet computer only 4 30 days after install, so if d d8 suddenly changes back by sum days/months/years its own time tracker gets messed up and so it refuses to work any more thinking sum 1 is trying to tampre wid d 30-day trial version
slugger is offline
Old 05-09-2007, 11:26 PM   #17 (permalink)
Wire muncher!
plz use the KISremoval tool. it solves most of the problems like this.
Download: Free Update Manager <Keeps your system up-to-date and problem free> Kiran.dks QnA (read only) 6 16-04-2007 11:57 PM
Mozilla Firefox new Add-ons Site with a date problem Anup Nair Technology News 1 25-03-2007 10:51 PM
Problem while inserting into oracle, date values frm vb nihilks Software Q&A 3 14-10-2006 02:38 PM
problem with system date in FC4 legolas Open Source 6 02-03-2006 02:59 PM
Battlefield 2 Release Date Rumor and System Specs Sourabh Gamerz 2 02-05-2005 03:23 PM
